Gigabyte-78lmt-usb3 3.0 usb ports stops working [SOLVED]
Hello!
It’s been awhile since I posted or been on the forum. For that I’m sorry it’s this new life we have…
I have bought several Gigabyte-78lmt-usb3 v5.0 and 1 v1.0 and they all have the same issue. The USB 3.0 ports stop working after a while and will not work until I reboot and then only work once. If I stop using the USB device the Data part stops working while the power side still works.
I have Searched Mint, MX, Ask Ubuntu and other forums and have not see issues for these boards but for USB 3 in general an mostly Windows. Now I can say that it does not make a hoot If it is Mint, MX. Arch, EndeavourOS, Debian they all have the same issue with these boards. I have all of these OS’s on all of them. They came from different sellers so nothing there could be a issue.
I have done a bunch of testing and searching last 2 days. My BTW Arch install has done this for 13 months was not a issue until now as my Dell Media Server 2 core 4 gig Mobo just needed updated. So I got these 4 boards that all have AMD 6 cores and 8 gig of ram.
I need to use my MiraBox Capture Card / box is a USB 3.0 HDMI Card/box to record my VHS tapes of the kids to my computer. Only have 40 or so tapes… Lol
But when I record some video and stop OBS to do some editing I found that the USB 3.0 ports are acting like my Arch computer with the same board and CPU. The USB 3.0 ports do not or stoped work. (Did not do this with the old Dell board)
Now the USB 2.0 ports work with no problem and when I have the MiraBox Capture Card / box on the USB 2.0 ports it works as it should and there are no issues with the ports. Did not have this with any of other the computers with USB 3.0 which are Asus and AsRock and a MSI boards.
I have a v1.0 of the 78lmt board in my sister’s computer that does the same thing. It was replaced last year. My BTW Arch computer is the same board as her’s…
The v1.0 boards are blue and the v5.0’s are black boards not that it should make a difference but someone will ask I’m sure. :smile:
So here are the testing I done with lsusb and lsusb -t…
INXI output!
Yes this is MX 19.3 but I have several of these boards that are all doing same thing no matter the OS that is installed. Arch or Ubuntu makes no difference…
System:    Host: <filter> Kernel: 4.14.14-antix.1-amd64-smp x86_64 bits: 64 compiler: gcc
           v: 7.2.0
           parameters: BOOT_IMAGE=/vmlinuz-4.14.14-antix.1-amd64-smp
           root=UUID=<filter> ro usbcore.autosuspend=-1 iommu=soft <<<<<----- I added these...---->>>>
           init=/lib/systemd/systemd
           Desktop: Xfce 4.14.2 tk: Gtk 3.24.5 info: xfce4-panel wm: xfwm4 dm: LightDM 1.26.0
           Distro: MX-19.3_x64 patito feo October 15  2019 base: Debian GNU/Linux 10 (buster)
Machine:   Type: Desktop Mobo: Gigabyte model: GA-78LMT-USB3 v: x.x serial: <filter> BIOS: Award
           v: F4 date: 10/19/2012
CPU:       Topology: 6-Core model: AMD FX-6300 bits: 64 type: MCP arch: Bulldozer
           family: 15 (21) model-id: 2 stepping: N/A microcode: 6000852 L2 cache: 2048 KiB
           flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 42187
           Speed: 1404 MHz min/max: 1400/3500 MHz boost: enabled Core speeds (MHz): 1: 1405
           2: 1406 3: 1405 4: 1403 5: 1405 6: 1405
           Vulnerabilities: Type: meltdown status: Not affected
           Type: spectre_v1 status: Vulnerable
           Type: spectre_v2 status: Vulnerable: Minimal AMD ASM retpoline
Graphics:  Device-1: AMD RS780L [Radeon 3000] vendor: Gigabyte driver: radeon v: kernel
           bus ID: 01:05.0 chip ID: 1002:9616
           Display: x11 server: X.Org 1.20.4 driver: ati,radeon unloaded: fbdev,modesetting,vesa
           resolution: 1920x1080~60Hz
           OpenGL: renderer: AMD RS780 (DRM 2.50.0 / 4.14.14-antix.1-amd64-smp LLVM 7.0.1)
           v: 3.3 Mesa 18.3.6 compat-v: 3.0 direct render: Yes
Audio:     Device-1: AMD SBx00 Azalia vendor: Gigabyte driver: snd_hda_intel v: kernel
           bus ID: 00:14.2 chip ID: 1002:4383
           Device-2: AMD RS780 HDMI Audio [Radeon 3000/3100 / HD 3200/3300]
           driver: snd_hda_intel v: kernel bus ID: 01:05.1 chip ID: 1002:960f
           Sound Server: ALSA v: k4.14.14-antix.1-amd64-smp
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte
           driver: r8169 v: 2.3LK-NAPI port: ee00 bus ID: 03:00.0 chip ID: 10ec:8168
           IF: eth0 state: up speed: 100 Mbps duplex: half mac: <filter>
Drives:    Local Storage: total: 1.37 TiB used: 789.27 GiB (56.4%)
           ID-1: /dev/sda vendor: Western Digital model: WD10EAVS-00M4B0 size: 931.51 GiB
           block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s serial: <filter> rev: 0A01
           scheme: MBR
           ID-2: /dev/sdb vendor: Maxtor model: 7Y250M0 size: 233.76 GiB block size:
           physical: 512 B logical: 512 B speed: 1.5 Gb/s serial: <filter> rev: 11W0 scheme: MBR
           ID-3: /dev/sdc vendor: Maxtor model: 7Y250M0 size: 233.76 GiB block size:
           physical: 512 B logical: 512 B speed: 1.5 Gb/s serial: <filter> rev: 1HW0 scheme: MBR
Partition: ID-1: / raw size: 87.89 GiB size: 86.01 GiB (97.86%) used: 8.16 GiB (9.5%) fs: ext4
           dev: /dev/sdc3
           ID-2: /boot raw size: 500.0 MiB size: 476.2 MiB (95.24%) used: 143.9 MiB (30.2%)
           fs: ext4 dev: /dev/sdc1
           ID-3: /home raw size: 138.55 GiB size: 135.37 GiB (97.71%) used: 56.97 GiB (42.1%)
           fs: ext4 dev: /dev/sdc4
           ID-4: swap-1 size: 6.84 GiB used: 17.8 MiB (0.3%) fs: swap
           swappiness: 15 (default 60) cache pressure: 100 (default) dev: /dev/sdc2
Sensors:   System Temperatures: cpu: 21.4 C mobo: N/A
           Fan Speeds (RPM): N/A
Repos:     No active apt repos in: /etc/apt/sources.list
           Active apt repos in: /etc/apt/sources.list.d/brave-browser-release.list
           1: deb [arch=amd64] https://brave-browser-apt-release.s3.brave.com/ buster main
           Active apt repos in: /etc/apt/sources.list.d/debian-stable-updates.list
           1: deb http://deb.debian.org/debian buster-updates main contrib non-free
           Active apt repos in: /etc/apt/sources.list.d/debian.list
           1: deb http://deb.debian.org/debian buster main contrib non-free
           2: deb http://deb.debian.org/debian-security buster/updates main contrib non-free
           Active apt repos in: /etc/apt/sources.list.d/google-chrome.list
           1: deb [arch=amd64] http://dl.google.com/linux/chrome/deb/ stable main
           Active apt repos in: /etc/apt/sources.list.d/mx.list
           1: deb http://mirror.math.princeton.edu/pub/mxlinux/mx/repo/ buster main non-free
           No active apt repos in: /etc/apt/sources.list.d/various.list
Info:      Processes: 263 Uptime: 8h 44m Memory: 7.30 GiB used: 1.65 GiB (22.6%) Init: systemd
           v: 241 runlevel: 5 default: 5 Compilers: gcc: 8.3.0 alt: 8 Shell: quick-system-in
           running in: quick-system-in inxi: 3.0.36
I got on the internet and did a bunch of searching and found these settings an added them to Grub Boot.
Keeps the Usb Capture card working now and the Usb 30 port does not stop working now until I shut down OBS then the Usb 3.0 ports goes away… The Dvd player is not being seen too!
usbcore.autosuspend=-1 iommu=soft (<-- Added to Grub)
lsusb
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 008: ID 1a40:0101 Terminus Technology Inc. Hub
Bus 001 Device 007: ID 0a81:0205 Chesen Electronics Corp. PS/2 Keyboard+Mouse Adapter
Bus 001 Device 006: ID 1a40:0101 Terminus Technology Inc. Hub
Bus 001 Device 004: ID 046d:c508 Logitech, Inc. Cordless Trackball
Bus 001 Device 002: ID 1a40:0101 Terminus Technology Inc. Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 011 Device 002: ID 1bcf:2c99 Sunplus Innovation Technology Inc.
Bus 011 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 010 Device 003: ID 13fd:1040 Initio Corporation INIC-1511L PATA Bridge
Bus 010 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 009 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 008 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Working USB 3.0
lsusb
NOT a Working USB 3.0 port…
lsusb -t
/:  Bus 11.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 5000M
/:  Bus 10.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 480M
/:  Bus 09.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 5000M
/:  Bus 08.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 480M
/:  Bus 07.Port 1: Dev 1, Class=root_hub, Driver=ohci-pci/2p, 12M
/:  Bus 06.Port 1: Dev 1, Class=root_hub, Driver=ohci-pci/3p, 12M
/:  Bus 05.Port 1: Dev 1, Class=root_hub, Driver=ohci-pci/3p, 12M
/:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=ohci-pci/3p, 12M
/:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ohci-pci/3p, 12M
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/6p, 480M
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/6p, 480M
    |__ Port 2: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
        |__ Port 2: Dev 4, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
        |__ Port 3: Dev 6, If 0, Class=Hub, Driver=hub/4p, 480M
            |__ Port 1: Dev 7, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
            |__ Port 1: Dev 7, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
            |__ Port 4: Dev 8, If 0, Class=Hub, Driver=hub/4p, 480M
    |__ Port 4: Dev 9, If 0, Class=Video, Driver=uvcvideo, 480M
    |__ Port 4: Dev 9, If 1, Class=Video, Driver=uvcvideo, 480M
    |__ Port 4: Dev 9, If 2, Class=Audio, Driver=snd-usb-audio, 480M
    |__ Port 4: Dev 9, If 3, Class=Audio, Driver=snd-usb-audio, 480M
With capture card in USB 2.0 port…
lsusb -t
Without capture card in USB 2.0
USB 3.0 will not work now at all with anything plugged in. Note: Still powers stuff…
Restarted the computer with the usb 3.0 capture card and Dvd player connected… video0 shows in /dev/…
lsusb
Bus 001 Device 005: ID 0a81:0205 Chesen Electronics Corp. PS/2 Keyboard+Mouse Adapter
Bus 001 Device 004: ID 1a40:0101 Terminus Technology Inc. Hub
Bus 001 Device 003: ID 046d:c508 Logitech, Inc. Cordless Trackball
Bus 010 Device 002: ID 13fd:1040 Initio Corporation INIC-1511L PATA Bridge
 lsusb -t
    |__ Port 2: Dev 2, If 0, Class=Video, Driver=uvcvideo, 5000M
    |__ Port 2: Dev 2, If 1, Class=Video, Driver=uvcvideo, 5000M
    |__ Port 2: Dev 2, If 2, Class=Audio, Driver=snd-usb-audio, 5000M
    |__ Port 2: Dev 2, If 3, Class=Audio, Driver=snd-usb-audio, 5000M
    |__ Port 1: Dev 2, If 0, Class=Mass Storage, Driver=usb-storage, 480M
        |__ Port 2: Dev 3, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
        |__ Port 3: Dev 4, If 0, Class=Hub, Driver=hub/4p, 480M
            |__ Port 1: Dev 5, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
            |__ Port 1: Dev 5, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
            |__ Port 4: Dev 6, If 0, Class=Hub, Driver=hub/4p, 480M
Unplugged Capture card and Dvd player and plugged them back in…
Bus 011 Device 003: ID 0781:5583 SanDisk Corp. Ultra Fit
lsusb -t
    |__ Port 2: Dev 4, If 0, Class=Video, Driver=uvcvideo, 5000M
    |__ Port 2: Dev 4, If 1, Class=Video, Driver=uvcvideo, 5000M
    |__ Port 2: Dev 4, If 2, Class=Audio, Driver=snd-usb-audio, 5000M
    |__ Port 2: Dev 4, If 3, Class=Audio, Driver=snd-usb-audio, 5000M
Started OBS and the Capture Card… Video and sound is working and does not
shut off after a while with the settings added to the Grub boot…
Bus 011 Device 004: ID 1bcf:2c99 Sunplus Innovation Technology Inc.
lsusb -t
Closed OBS and the Usb 3.0 Capture Card and Dvd player are no longer seen.
The file manager no longer sees the Dvd drive and the video0 in /dev/
is also gone. Unpluged an re-plug both and still not recognized…
lsusb -t
So if anyone has any idea where to go short of not using USB 3.0 on these boards… Lol
I’m using more and more USB 3 stuff so this is now a issue…
I have seen all kinds of USB 3.0 issues on the web but it is mostly Windows 7 / 10 issues with drivers and the 2 switches I added to the boot Grub was from Ask Ubuntu…
Thanks in advance for your help! (If you can. :smile: )
Bruce
LLAP
try with
sudo udevadm monitor
and plug /unplug USB3.0
Hello @Stephane and thank you for replying.
I did use the command you suggested and it was a good diag tool…
I came to find that the USB 3.0 chip was flaky. I also read that this was a known issue with that series of boards. So I did get the others boards working where the USB 3.0 do not stop working with the commands in she start of the post.
So thanks for the thoughts…
LLAP
Ok folks I am glad after a week of testing and searching the net. I have found some issues that I got fixed and some I did not.
On the other 4 Gigabyte 78lamt-USB3 boards that are version 5.4 I got the sleeping/stopping issue fixed it by commands entered in the Grub boot process.
I found these 2 command “usbcore.autosuspend=-1” " iommu=soft" and added them to the
GRUB_DEFAULT="0"
GRUB_TIMEOUT="7"
GRUB_DISTRIBUTOR="Arch"
GRUB_CMDLINE_LINUX_DEFAULT="loglevel=3 usbcore.autosuspend=-1 iommu=soft acpi=off apm=off"
GRUB_CMDLINE_LINUX=""
affter adding them to the V5.1 boards my issues was fixed.
Now the 2 version 4.1 mobos it did not help but I found that those were flaky from the command that @Stephane suggested. the fix was…
I got on Amazon and bought 2 PCIe add-on USB 3.0 cards and now the USB 3.0 ports now work and OBS, the Capture Card, Dvd Player all work now with no issues on the v4.1 mobos.
I watch a video from Explaining Computer Youtube channel on upgrading a old computer to have USB 3.0. So this was great and I’m glad he made the video :slight_smile:
This all from the really the crappy USB 3.0 chipsets that Gigabyte bought from a 3rd party vender instad of making it as they usually do…
I did get a good deal on the boards though and they all had 6 core AMD 8 gigs of ram on the boards so I can’t complain to much… I wanted the 6 cores… Lol
So I have the issues fixed and i hope this helps someone else with these boards.
So I am marking this as Solved…
Bruce
LLAP
