Hi, just out of curiosity,
I haven’t used my machine for a while.
Now updating it says
Total Download size 1120MiB
Total installed 4884MiB
Net upgrade Size -82MiB
Why is the net upgrade in the minus ??
Thanks
Thanks
I guess it means the updated packages are smaller than the ones they replaced.
Have you not upgraded since the linux-firmware
split perhaps?
It’s getting rid of the bloat.
What’s that?
And yes I have’nt updated the system for at least 10 days.
But that is now one month old news.
thank you.
Nothing for me to worry about, then. (As I don’t unedrstand a word of what it says… )
You must have done the update back then and you’re good.
@dalto's
“the updated packages are smaller than the ones they replaced” is the more likely explanation then.
