keychain --help
does not produce any output and seems to hang.
However, both sh keychain --help
and bash keychain --help
seem to work fine.
This happens both in xfce4-terminal
and tty.
How to fix?
What is your default shell?
The funtoo keychain has a dependancy on bash
, which explains why sh/bash
work.
The odd thing is tty, as generally for EOS that is bash. Have you used chsh
(or some other way) to change the system shell?
$SHELL
prints /bin/bash
for both terminal and tty
Every thing seems to point to bash but keychain
by itself seems to hang.
/bin/bash keychain
also works
I do not recall using chsh
[underscore@GrapesJuicyJuice ~]$ echo $SHELL
/bin/bash
[underscore@GrapesJuicyJuice ~]$ which sh
/usr/bin/sh
[underscore@GrapesJuicyJuice ~]$ ls -l /usr/bin/sh
lrwxrwxrwx 1 root root 4 May 21 05:56 /usr/bin/sh -> bash
[underscore@GrapesJuicyJuice ~]$ which bash
/usr/bin/bash
Found the offending line
[underscore@GrapesJuicyJuice ~]$ alias keychain
alias keychain='eval $(keychain --eval --quiet id_ed25519)'
I think I copied this line from arch wiki. gotta go find and remove now.
