Maybe that’s why I accidentally on purpose sailed into here
OK, so incredibly serious question:
Why don’t sky ships have sails on more than one side of the hull?
Because then they wouldn’t look as cool?
Less cool, or more cool ?
Because anime…
I guess it depends on your perspective?
OK, now I want to try drawing a sky ship…
If it is a ghost ship, like der fliegende Holländer, then that was a normal ship once when its crew was alive, so it makes sense to have the sails in the normal places, now it just sails on the fog, because ghosts, and stuff…
But if it is ship designed to be flying, then it makes little sense to put sails only on top (because the force these sails would generate would create torque on the entire vessel). Also, it needs something to generate lift for it, probably a balloon (in high steampunk fantasy, this can be a vacuum chamber made of some extremely tough, but light material).
When it comes to a fantasy sailing blimp, I like this arrangement of sails:
Though, manually operating these sails must be a pain for the crew.
Also, how are the masts attached to the blimp? Are they going through it?
Welcome!
Probably - the interior will have a frame so the masts will just be part of that.
Thanks @anon14644943 still only just dumped iso on usb, at this rate i should be done by lunch next week
Welcome to the community
Also, for the masts on all sides… wouldn’t that make it hard to land?
Use a skydock.
Sure, it couldn’t land flat on the ground, it would have to be anchored while in the sky (and the passangers would descend and ascend using some sort of a cabin on a cable), or docked to a tower.
But it needs the sails all around, because of the torque. If it had the sails only on the top side, it would tilt downwards and, in heavy wind, spin out of control (like a maple tree seed).
It could have the sails only on the sides and not on top and bottom. That would cancel the torque, while still allowing it to land on a flat land. But ships rarely need to land, and having the sails all around would be more efficient.
If you ever played Kerbal Space Program, you know that for all flying vessels the centre of mass has to be on the line spanned by the vector of thrust
to keep people from using them as giant trampolines/hammocks
