Fresh installation, can't update packages (Unresolvable conflicts and Missing AUR packages)
Hi, just installed the system and tried to update packages but with no luck…
I get these errors:
:: Replace hwids with core/hwdata? [Y/n] Y
resolving dependencies...
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
:: jack2 and pipewire-jack are in conflict
AUR update check:
:: Searching AUR for updates...
 -> Missing AUR Packages:  hwids
 there is nothing to do
Screenshot of the terminal window
What might be wrong?
Try this:
sudo pacman -Syu pipewire-jack
The missing AUR package is because the replacement failed. Once the update works, that message will go away.
Also…Welcome to the forum!
Thank you very much for your welcome, I have pasted your line to the terminal but unfortunately, still getting the same error.
:: pipewire-jack and jack2 are in conflict
sudo pacman -Rdd jack2
That seemed to work, thank you! However, in the later stages of the update I get these corrupted file errors… Could you please help with those?
 Total (319/319)                 974,6 MiB  8,93 MiB/s 01:49 [--------------------------------] 100%
(319/319) checking keys in keyring                           [--------------------------------] 100%
downloading required keys...
:: Import PGP key 11675C743429DDEF, "Massimiliano Torromeo <mtorromeo@archlinux.org>"? [Y/n] Y
:: Import PGP key E85B8683EB48BC95, "Daniel Bermond <dbermond@archlinux.org>"? [Y/n] Y
:: Import PGP key C132293954BBE4AD, "Sergej Pupykin <spupykin@archlinux.org>"? [Y/n] Y
:: Import PGP key E1E3CF0539448BFF, "Ike Devolder <ike.devolder@archlinux.org>"? [Y/n] Y
:: Import PGP key 4A2B758631E1FD91, "Maxim Baz <maximbaz@archlinux.org>"? [Y/n] Y
:: Import PGP key 59E43E106B247368, "Leonidas Spyropoulos <artafinde@archlinux.org>"? [Y/n] Y
:: Import PGP key 6E7CE0B0A36DA2AE, "Brett Cornwall <brett@i--b.com>"? [Y/n] Y
(319/319) checking package integrity                         [--------------------------------] 100%
error: libmfx: key "80247D99EABD3A4D1E3A1836E85B8683EB48BC95" is unknown
:: Import PGP key 80247D99EABD3A4D1E3A1836E85B8683EB48BC95? [Y/n] Y
:: File /var/cache/pacman/pkg/libmfx-22.1.0-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n] Y
:: File /var/cache/pacman/pkg/vmaf-2.3.0-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: lightdm-slick-greeter: signature from "Alexander Epaneshnikov <email@alex19ep.me>" is unknown trust
:: File /var/cache/pacman/pkg/lightdm-slick-greeter-1.5.6-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: spice-vdagent: key "35BAE1BF9A6B317021E690C26E7CE0B0A36DA2AE" is unknown
:: Import PGP key 35BAE1BF9A6B317021E690C26E7CE0B0A36DA2AE? [Y/n] Y
:: File /var/cache/pacman/pkg/spice-vdagent-0.22.1-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
:: File /var/cache/pacman/pkg/tldr-3.1.0-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: failed to commit transaction (invalid or corrupted package)
sudo pacman -Sy archlinux-keyring
Thanks again. Wish that such a simple thing would work out of the box especially since EndavourOS is advertised as one of the most beginner friendly distros…
It is because you did an offline install and the current ISO is 2 months old. You are basically applying 2 months of updates at the same time. On an Arch-based distro, waiting that long between updates will often require some manual intervention.
With an online install, that wouldn’t have happened.
I have just tried the online installation. Everything seemed fine, and I clicked on Reboot after the installation. After rebooting, there was no desktop environment. Only a shell prompting me to type my login info I guess I may give Endeavour another go later, but not today. It seems not very newbie friendly as of today.
Did you select a desktop environment when you did the install? If not, there won’t be one. The next version of the ISO currently in development will make this more obvious.
To be fair, while we welcome users of all skill levels including complete beginners, we don’t describe ourselves as a distro for beginners.
If you don’t mind, if you could link to wherever you saw us advertised as a beginner distro, especially as one of the most beginner friendly distros?? I’d love to reach out to them and get that adjusted. That’s unfair to folks like yourself who come here expecting one thing to find out it’s not true. Setting that expectation is going to lead to a lot of disappointed folks.
To clarify my opinion on beginners, EndeavourOS is not a distro where someone with zero knowledge will have everything perfect out of the box.
It is a place where users of all skill levels are welcome and we have many great community members who are glad to help out if and when you have problems.
We have had many total beginners that have started with us and grown into active members of the community and are now helping others.
agree with this, but also agree with @fbodymechanic that this should not be advertised as a distro for beginner.
Whether EOS is user friendly is a matter of perspective. What i can say without doubt is if you want an arch based distro then EOS forum is the most helpful and friendly one there is
Beginner Friendly yes … but not in the meaning of easy to use in the same workflow as you are used on WindowsOS :wink: it is simply arch with some help and helper tools to manage archbased systems but not handholding and automatically preconfigured for any use-case only a basic setup to start to set everything up as you like/need
Perhaps it should be emphasized more that an online installation is preferable if the internet connection allows it.
Due to the nature of a rolling distribution… (saves updates, reduces problem possibilities etc)
Sounds good to me. Of course, I went to online installs exclusively once they were faster than offline! :grin:
Hey Debloat
just give it a try, its worth :wink:
