my amdgu freezes resp. the PC freezes when I use kernel command line parameter acpi_enforce_resources=lax together with kernel 5.12. The freeze happens when I log out and let my PC sit idle for 10 min.
journal
Jun 05 18:11:25 rakete kernel: [drm] free PSP TMR buffer
Jun 05 18:12:02 rakete kernel: [drm] PCIE GART of 512M enabled (table at 0x0000008000000000).
Jun 05 18:12:02 rakete kernel: [drm] PSP is resuming...
Jun 05 18:12:02 rakete kernel: [drm] reserve 0x900000 from 0x800f400000 for PSP TMR
Jun 05 18:12:02 rakete kernel: amdgpu 0000:0e:00.0: amdgpu: RAS: optional ras ta ucode is not available
Jun 05 18:12:02 rakete kernel: amdgpu 0000:0e:00.0: amdgpu: RAP: optional rap ta ucode is not available
Jun 05 18:12:02 rakete kernel: amdgpu 0000:0e:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
Jun 05 18:12:02 rakete kernel: amdgpu 0000:0e:00.0: amdgpu: SMU is resuming...
Jun 05 18:12:02 rakete kernel: amdgpu 0000:0e:00.0: amdgpu: smu driver if version = 0x00000036, smu fw if version = 0x00000037, smu fw version = 0x002a3f00 (42.63.0)
Jun 05 18:12:02 rakete kernel: amdgpu 0000:0e:00.0: amdgpu: SMU driver if version not matched
Jun 05 18:12:04 rakete kernel: amdgpu 0000:0e:00.0: amdgpu: message: EnableAllSmuFeatures (6) param: 0x00000000 is timeout (no response)
Jun 05 18:12:04 rakete kernel: amdgpu 0000:0e:00.0: amdgpu: Failed to enable requested dpm features!
Jun 05 18:12:04 rakete kernel: amdgpu 0000:0e:00.0: amdgpu: Failed to setup smc hw!
Jun 05 18:12:04 rakete kernel: [drm:amdgpu_device_ip_resume_phase2 [amdgpu]] *ERROR* resume of IP block <smu> failed -62
Jun 05 18:12:04 rakete kernel: amdgpu 0000:0e:00.0: amdgpu: amdgpu_device_ip_resume failed (-62).
Jun 05 18:12:04 rakete kernel: snd_hda_intel 0000:0e:00.1: refused to change power state from D3hot to D0
Jun 05 18:12:04 rakete kernel: amdgpu: Move buffer fallback to memcpy unavailable
Jun 05 18:12:04 rakete kernel: [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to process the buffer list -19!
Jun 05 18:12:05 rakete kernel: amdgpu: Move buffer fallback to memcpy unavailable
Jun 05 18:12:05 rakete kernel: [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to process the buffer list -19!
Jun 05 18:12:05 rakete kernel: snd_hda_intel 0000:0e:00.1: CORB reset timeout#2, CORBRP = 65535
Jun 05 18:12:15 rakete kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring sdma1 timeout, signaled seq=37233, emitted seq=37235
Jun 05 18:12:15 rakete kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process pid 0 thread pid 0
Jun 05 18:12:15 rakete kernel: amdgpu 0000:0e:00.0: amdgpu: GPU reset begin!
Jun 05 18:12:15 rakete kernel: ------------[ cut here ]------------
Jun 05 18:12:15 rakete kernel: kernel BUG at mm/slub.c:314!
Jun 05 18:12:15 rakete kernel: invalid opcode: 0000 [#1] PREEMPT SMP NOPTI
Jun 05 18:12:15 rakete kernel: CPU: 5 PID: 313159 Comm: kworker/5:0 Tainted: P OE 5.12.9-zen1-1-zen #1
Jun 05 18:12:15 rakete kernel: Hardware name: Gigabyte Technology Co., Ltd. X570 AORUS ULTRA/X570 AORUS ULTRA, BIOS F33 05/21/2021
Jun 05 18:12:15 rakete kernel: Workqueue: events drm_sched_job_timedout [gpu_sched]
Jun 05 18:12:15 rakete kernel: RIP: 0010:__slab_free+0x292/0x5b0
Jun 05 18:12:15 rakete kernel: Code: c9 0f 84 95 00 00 00 48 8b 44 24 78 65 48 2b 04 25 28 00 00 00 0f 85 80 02 00 00 48 8d 65 d8 5b 41 5c 41 5d 41 5e 41 5f 5d c3 <0f> 0b 65 ff 0d b5 a5 8d 50 0f 84 e6 00 00 00 f3 90 49 8b 04 24 a8
Jun 05 18:12:15 rakete kernel: RSP: 0018:ffffb2e54874bc80 EFLAGS: 00010246
Jun 05 18:12:15 rakete kernel: RAX: ffffa08cdfafcd00 RBX: ffffa08cdfafcc00 RCX: ffffa08cdfafcc00
Jun 05 18:12:15 rakete kernel: RDX: 000000008020001f RSI: ffffe9dd447ebf00 RDI: ffffa08cc0042a00
Jun 05 18:12:15 rakete kernel: RBP: ffffb2e54874bd30 R08: 0000000000000001 R09: ffffffffc187c9e1
Jun 05 18:12:15 rakete kernel: R10: ffffa09bff242000 R11: ffffb2e54874ba40 R12: ffffe9dd447ebf00
Jun 05 18:12:15 rakete kernel: R13: ffffa08cdfafcc00 R14: ffffa08cc0042a00 R15: ffffa08cdfafcc00
Jun 05 18:12:15 rakete kernel: FS: 0000000000000000(0000) GS:ffffa09bbeb40000(0000) knlGS:0000000000000000
Jun 05 18:12:15 rakete kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Jun 05 18:12:15 rakete kernel: CR2: 00007f6bdfd7dfa8 CR3: 0000000301584000 CR4: 0000000000350ee0
Jun 05 18:12:15 rakete kernel: Call Trace:
Jun 05 18:12:15 rakete kernel: ? __flush_work.isra.0+0x18e/0x210
Jun 05 18:12:15 rakete kernel: ? kfd_gtt_sa_free+0x56/0x80 [amdgpu]
Jun 05 18:12:15 rakete kernel: ? kernel_queue_uninit+0x81/0xe0 [amdgpu]
Jun 05 18:12:15 rakete kernel: kernel_queue_uninit+0x81/0xe0 [amdgpu]
Jun 05 18:12:15 rakete kernel: stop_cpsch+0xa0/0xc0 [amdgpu]
Jun 05 18:12:15 rakete kernel: kgd2kfd_pre_reset+0x56/0x80 [amdgpu]
Jun 05 18:12:15 rakete kernel: amdgpu_device_gpu_recover.cold+0x2a8/0xa58 [amdgpu]
Jun 05 18:12:15 rakete kernel: amdgpu_job_timedout+0x128/0x150 [amdgpu]
Jun 05 18:12:15 rakete kernel: drm_sched_job_timedout+0x64/0xe0 [gpu_sched]
Jun 05 18:12:15 rakete kernel: process_one_work+0x214/0x3e0
Jun 05 18:12:15 rakete kernel: worker_thread+0x4d/0x470
Jun 05 18:12:15 rakete kernel: ? process_one_work+0x3e0/0x3e0
Jun 05 18:12:15 rakete kernel: kthread+0x181/0x1b0
Jun 05 18:12:15 rakete kernel: ? __kthread_init_worker+0x50/0x50
Jun 05 18:12:15 rakete kernel: ret_from_fork+0x22/0x30
Jun 05 18:12:15 rakete kernel: Modules linked in: uas usb_storage cfg80211 ccm algif_aead cbc des_generic libdes ecb algif_skcipher cmac md4 algif_hash af_alg it87(OE) hwmon_vid amdgpu rc_tt_1500 stb6100 isl6423 stb0899 dvb_usb_pctv452e(OE) dvb_usb(OE) snd_hda_codec_realtek snd_hda_codec_generic ledtrig_audio snd_hda_codec_hdmi ttpci_eeprom dvb_core intel_rapl_msr snd_hda_intel snd_intel_dspcfg videobuf2_vmalloc intel_rapl_common snd_intel_sdw_acpi videobuf2_memops amd64_edac btusb edac_mce_amd videobuf2_common btrtl btbcm snd_hda_codec gpu_sched btintel drm_ttm_helper videodev lzo_rle ttm bluetooth kvm_amd snd_hda_core snd_hwdep mc snd_pcm drm_kms_helper ecdh_generic kvm rfkill snd_timer cec ecc snd crc16 syscopyarea irqbypass sysfillrect igb rapl sysimgblt wmi_bmof mxm_wmi soundcore fb_sys_fops k10temp i2c_piix4 i2c_algo_bit dca acpi_cpufreq vfat fat drm fuse agpgart zram ip_tables x_tables usbhid zfs(POE) xfs zunicode(POE) zzstd(OE) zlua(OE) libcrc32c zavl(POE) crc32c_generic icp(POE) zcommon(POE)
Jun 05 18:12:15 rakete kernel: znvpair(POE) spl(OE) crct10dif_pclmul crc32_pclmul crc32c_intel ghash_clmulni_intel aesni_intel crypto_simd ccp cryptd rng_core sr_mod cdrom xhci_pci xhci_pci_renesas wmi pinctrl_amd vboxnetflt(OE) vboxnetadp(OE) vboxdrv(OE) pkcs8_key_parser sg crypto_user
Jun 05 18:12:15 rakete kernel: ---[ end trace 4f4690ebc468e2b1 ]---
Jun 05 18:13:00 rakete kernel: amdgpu: Move buffer fallback to memcpy unavailable
Jun 05 18:13:00 rakete kernel: [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to process the buffer list -19!
Jun 05 18:14:00 rakete kernel: amdgpu: Move buffer fallback to memcpy unavailable
Jun 05 18:14:00 rakete kernel: [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to process the buffer list -19!
