They write about it here. https://bbs.archlinux.org/viewtopic.php?id=223909 https://www.reddit.com/r/archlinux/comments/3k4lq3/help_switching_from_grub_to_systemdboot/
It will be a bit more complicated than that because EOS has the efi partition mounted at /boot/efi
. If anyone is actually interested in converting I can write a tutorial that is tested with EOS.
The main advantage is simplicity. However, that simplicity comes at the cost of functionality so it probably isnât something everyone will want.
the fat32 of efi by calamares was set to MSdata smething i changed to EF00 and remounted the /boot to /boot/efi if i entered boot i see /boot/EFI
i also put alll the images in
Thank you for your reply. There will surely be some who will be interested in this.
The pursuit of simplicity is quite common today, it seems to be in the Linux world as well. Is systemd-boot good for the average user at all? What functions are missing in systemd-boot that are in grub? Iâm thinking of starting Windows, for example.
Sure, I donât see why it wouldnât be.
Cons
- systemd-boot requires the kernels/initrds to be in the EFI partition, grub doesnât
- The side effect of that, it it makes it tricky to do something like dual-boot two copies of eos because the kernels would collide unles you did something special
- It also means that the efi partition has to be larger. If you have 100MB efi partition that probably isnât going to work
- It is UEFI only, there is no support for legacy boot
- Grub has a fleet of options for graphical customizations of the menu
Neutral
- systemd-boot can boot windows without issue.
- It can also multi-boot linux distros as long as the kernels donât collide. For example, I am booting Windows/Arch/Manjaro/Nixos/Fedora at the moment on my main workstation
Pros
- Almost everything âjust worksâ without any configuration, encryption/btrfs/zfs/etc
- Nothing has to be rebuilt. If you need to change something you edit the entry file. In most cases that isnât even needed.
- Because the config is simple, it is also easy to read
GRUB also has abundant documentation, is very often used as the default boot-loader and it doesnât require systemdâŚ
Given how complicated it is, it needs it
Well grub is quite complicated for the average user, it is often a challenge even for an experienced user.
I hate grub (I believe it hates me too ). Luckily I donât multi-boot (much)
So if I understand correctly, it is enough to edit the entry file in systemd, in grub it is more difficult to configure. Systemd-boot was developed by Arch, but can it be used in any distribution that uses systemd?
I am pretty sure it was developed by the systemd devs but I guess I never investigated the history.
Yes, it should be able to.
Then I wonder if you donât even use any bootloaders?
I do, the default one. I just prefer not to touch anything if it boots
Thanks. All my appreciation, you are an expert on systemd (too)
Just wondering how it handles microcode, resume, quiet etc. Am I doomed to a visit to the Archwiki? Just for interestâs sake, of course - Iâll stick to rEFInd for the foreseeableâŚ
I already thought you invented Linux without a bootloader.
There are a few alternatives. https://www.ubuntupit.com/best-linux-bootloader-for-home-and-embedded-systems/
Well, technically speaking systemd-boot is not a boot-loader, but a boot manager . I didnât invent it though, and donât ask me whatâs the difference
edit: apparently it uses EFI Stub Loader as the bootloader
I think the easiest way to answer that would be to show you one of my entries:
title Arch Linux LTS
linux /vmlinuz-linux-lts
initrd /amd-ucode.img
initrd /initramfs-linux-lts.img
options zfs=zproot/ROOT/arch/root rw amd_iommu=on iommu=pt vfio-pci.ids=10de:1b80,10de:10f0
The options
section is for the kernel options like resume/quite/etc. I have quite a few because I am doing PCI-passthrough and using zfs.
PS. That is isnât a snippet. That is the entire config.
So very similar to the refind_linux.conf next to each bootable from rEFInd then. It certainly cuts down on the âupdates after the updatesâ problem! Having them boot from the esp is the only problem then, it seems. I have too many Arch-based systems at once to even contemplate it!
