New EnOS user here. Just installed EnOS on my macbook pro. Love it!
Currently having a font display issue in a few apps, for example Audacious. The font in the UI is obvious off from the system setting. See pic in the link,
Have tried to force it in ~/.config/audacious/gtkrc & ~/.gtkrc-2.0. No luck so far. Had the same issue in gimp. Was able to fix it in ~/.config/GIMP/2.10/gtkrc.
Thanks for the info. It’s indeed caused by incorrect DPI setting in fontconfig. It’s resolved by setting correct xft.dpi in ~/.Xdefaults ( took a shortcut ) .
