Font options not being applied
I’ve tried to increase the size of the fonts on my menu and nothing changed.
Related info:
inxi -Fixz
  Kernel: 6.6.15-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    Desktop: KDE Plasma v: 5.27.10 Distro: EndeavourOS base: Arch Linux
  Mobo: ASUSTeK model: TUF GAMING X670E-PLUS WIFI v: Rev 1.xx
    serial: <superuser required> UEFI: American Megatrends v: 1813
    date: 10/13/2023
  Info: 8-core model: AMD Ryzen 7 7800X3D bits: 64 type: MT MCP arch: Zen 4
    rev: 2 cache: L1: 512 KiB L2: 8 MiB L3: 96 MiB
  Speed (MHz): avg: 3155 high: 4386 min/max: 400/5050 cores: 1: 4312 2: 3503
    3: 3835 4: 4209 5: 4386 6: 4384 7: 400 8: 400 9: 4335 10: 3828 11: 4087
    12: 400 13: 3509 14: 4384 15: 4121 16: 400 bogomips: 134194
  Device-1: NVIDIA GA106 [GeForce RTX 3060] vendor: eVga.com. driver: nvidia
    v: 545.29.06 arch: Ampere bus-ID: 01:00.0
  Device-2: Logitech Logitech Webcam C925e driver: snd-usb-audio,uvcvideo
    type: USB bus-ID: 7-2:3
  Display: x11 server: X.Org v: 21.1.11 driver: X: loaded: nvidia
    unloaded: modesetting gpu: nvidia,nvidia-nvswitch resolution: 2560x1440
  API: EGL v: 1.5 drivers: nvidia,swrast platforms:
    active: gbm,x11,surfaceless,device inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 545.29.06
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
  API: Vulkan v: 1.3.276 drivers: nvidia surfaces: xcb,xlib devices: 1
  Device-1: NVIDIA GA106 High Definition Audio vendor: eVga.com.
    driver: snd_hda_intel v: kernel bus-ID: 01:00.1
  Device-2: AMD Family 17h/19h HD Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel bus-ID: 10:00.6
  Device-3: Logitech Logitech Webcam C925e driver: snd-usb-audio,uvcvideo
  API: ALSA v: k6.6.15-1-lts status: kernel-api
  Server-1: PipeWire v: 1.0.3 status: active
  Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
    port: e000 bus-ID: 09:00.0
  IF: eno1 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IP v4: <filter> type: dynamic noprefixroute scope: global
  IP v6: <filter> type: dynamic noprefixroute scope: global
  IP v6: <filter> type: noprefixroute scope: link
  Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
    vendor: Foxconn driver: mt7921e v: kernel bus-ID: 0a:00.0
  WAN IP: <filter>
Bluetooth:
  Device-1: Foxconn / Hon Hai Wireless_Device driver: btusb v: 0.8 type: USB
    bus-ID: 3-2:2
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.3
    lmp-v: 12
  Local Storage: total: 3.09 TiB used: 175.16 GiB (5.5%)
  ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 980 1TB size: 931.51 GiB
    temp: 32.9 C
  ID-2: /dev/sda vendor: Kingston model: SA400S37480G size: 447.13 GiB
  ID-3: /dev/sdb vendor: A-Data model: SU630 size: 447.13 GiB
  ID-4: /dev/sdc vendor: Kingston model: SA400S37480G size: 447.13 GiB
  ID-5: /dev/sdd vendor: Kingston model: SA400S37960G size: 894.25 GiB
  ID-1: / size: 873.81 GiB used: 43.47 GiB (5.0%) fs: ext4 dev: /dev/sdd1
  ID-2: /home size: 439.04 GiB used: 131.19 GiB (29.9%) fs: ext4
    dev: /dev/sda1
  ID-1: swap-1 type: file size: 1.95 GiB used: 49 MiB (2.5%) file: /swapfile
  System Temperatures: cpu: 41.9 C mobo: N/A
  Fan Speeds (rpm): N/A
  Processes: 373 Uptime: 15m Memory: total: 32 GiB note: est.
  available: 31.06 GiB used: 5.48 GiB (17.6%) Init: systemd Compilers:
  gcc: 13.2.1 Packages: 1257 Shell: Bash v: 5.2.26 inxi: 3.3.31
Running:
$ systemctl --user restart plasma-plasmashell.service
fix the issue
