So do you have internet? Test:
ping www.bbc.co.uk
ping www.bbc.co.uk
Ok so I tried the pacman command once again, This time it asks me if I am sure there is no package manager already running and it is asking me to remove var/lib/pacman/db.lck
sudo rm /var/lib/pacman/db.lck
The test worked alright!
haha
Also the command worked out
I edited my last comment - not awake, typing like gibberish is my first language
xD I tried the edited comment, it worked, let me try that xfce cmd again
There are 15 members in the group xfce4:
1.x
2.x
3.x
Enter a selection:
which one?
All, then reboot and select xfce from the desktop manager.
How do I select all? it says default=all but where/what is the default key? I am totally not a simpson in disguise
Press Enter
Now it gives me 37 options
Press Enter again
Nvm i pressed enter again
Edit: yes i did that
Done! So I reboot now?
Also! In between it said a few files were not able to be retrieved… specifically xfce4-settings
Lemme reboot…
sudo pacman -S xfce4-settings
Will reinstall it.
