Firefox and "start menu" flickering white and black rentangles
I have a dualboot with Windows 11 and Endeavouros. I thought the problem of the flickering white/transparent rectangle (firefox) at full width (i.e. if I shrink the firefox window it shrinks the scope of the rectangle as well) was due to an outdated amd driver or hardware acceleration that was enabled however this is not the case. I cannot record this problem through the computer because the video shows me that such a problem does not exist.
I have observed a similar problem (black rectangle) also when I use the windows key, but only when I hover over the application and then somewhere to the side. I have not been able to observe this problem anywhere else
I am using Gnome as desktop environment, and I installed Endeavouros yesterday
Update: I think the problem is kernel related, because after downgrading the kernel version the problem disappeared. Is there anything else I can do?
If that’s happening in the main line kernel, then try the linux-lts.
Couple things you can try…
  • X11 or Waylad session? Whichever one you’re using, try the other.
  • Try the LTS Kernel? Try the Zen kernel? I have three kernels installed for troubleshooting…
❯ pacman -Q | grep linux
archlinux-appstream-data 20241214-1
archlinux-keyring 20241203-1
linux 6.12.8.arch1-1
linux-api-headers 6.10-1
linux-firmware 20241210.b00a7f7e-1
linux-firmware-whence 20241210.b00a7f7e-1
linux-headers 6.12.8.arch1-1
linux-lts 6.6.69-1
linux-lts-headers 6.6.69-1
linux-zen 6.12.8.zen1-1
linux-zen-headers 6.12.8.zen1-1
util-linux 2.40.2-3
util-linux-libs 2.40.2-3
