xircon
March 17, 2022, 7:42pm
1
How do I make the bar thinner? and/or can I make it toggle?
Have tried altering height in config and font in css.
[common/ipc-client.c:67] Unable to connect to /run/user/1000/sway-ipc.1000.999.sock
am getting this error, may have missed a package or making something executable.
Other than that seems to work OK, considering it is a manual install
What Graphics card are you running it on?
xircon
March 17, 2022, 8:46pm
3
Intel built in:
Device-1: Intel 4th Gen Core Processor Integrated Graphics driver: i915
v: kernel
Display: wayland server: X.Org v: 1.21.1.3 with: Xwayland v: 22.1.0
compositors: 1: Qtile v: 0.20.1.dev81+ge4d0684f 2: Picom v: git-a8445
driver: X: loaded: modesetting unloaded: fbdev,vesa gpu: i915
resolution: 1600x900~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 4600 (HSW GT2)
v: 4.5 Mesa 21.3.7
xircon
March 17, 2022, 8:47pm
5
Yes, not bad, but am back in qtile at the moment.
eosbtw
March 18, 2022, 10:04am
6
Re. style.css, does changing the font-size value in the section below not affect the dimensions?
/* The whole bar */
#waybar {
background: transparent;
color: #bebebe;
background-color: @base1;
font-family: UbuntuMono;
font-size: 14px;
After saving the file, a reload with $mod+Shift+c
is required make the changes take effect.
xircon
March 18, 2022, 11:15am
7
Nope, doesnβt work, one of the widgets is forcing the bar to be 42px. Have found a replacement and am re-configuring it to my needs
Will reinstall the configs later, kill the bar and post the errors when I restart it. But will be much later, got stuff on.
