I’ve been getting the error
failed to unmount /home
during shutdown for the last week or so. Not sure what exactly might be causing this.
Here’s some output from journalctl
Jul 08 15:44:02 pavilion systemd[1]: Stopped Create Volatile Files and Directories.
Jul 08 15:44:02 pavilion systemd[1]: Stopped target Local File Systems.
Jul 08 15:44:02 pavilion systemd[1]: Unmounting /boot/efi...
Jul 08 15:44:02 pavilion audit: BPF prog-id=0 op=UNLOAD
Jul 08 15:44:02 pavilion systemd[1]: Unmounting /home...
Jul 08 15:44:02 pavilion systemd[1]: Unmounting /mnt/storage...
Jul 08 15:44:02 pavilion systemd[1]: Unmounting /run/credentials/systemd-sysusers.service...
Jul 08 15:44:02 pavilion umount[54571]: umount: /home: target is busy.
Jul 08 15:44:02 pavilion systemd[1]: Unmounting /tmp...
Jul 08 15:44:02 pavilion systemd[1]: Unmounting /var/cache/pacman/pkg...
Jul 08 15:44:02 pavilion systemd[1]: Stopping Flush Journal to Persistent Storage...
Jul 08 15:44:02 pavilion systemd[1]: home.mount: Mount process exited, code=exited, status=32/n/a
Jul 08 15:44:02 pavilion systemd[1]: Failed unmounting /home.
Jul 08 15:44:02 pavilion systemd[1]: var-cache-pacman-pkg.mount: Deactivated successfully.
Jul 08 15:44:02 pavilion systemd[1]: Unmounted /var/cache/pacman/pkg.
Jul 08 15:44:02 pavilion systemd[1]: Unmounting /var/cache...
Here’s my /etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=1A14-AF0E /boot/efi vfat umask=0077 0 2
UUID=792fd0e5-0942-45cc-b07b-400213890a85 / btrfs subvol=/@,defaults,noatime,space_cache,noautodefrag,compress=lzo 0 1
UUID=792fd0e5-0942-45cc-b07b-400213890a85 /home btrfs subvol=/@home,defaults,noatime,space_cache,noautodefrag,compress=lzo 0 2
UUID=792fd0e5-0942-45cc-b07b-400213890a85 /var/cache btrfs subvol=/@cache,defaults,noatime,space_cache,noautodefrag,compress=lzo 0 2
UUID=792fd0e5-0942-45cc-b07b-400213890a85 /var/log btrfs subvol=/@log,defaults,noatime,space_cache,noautodefrag,compress=lzo 0 2
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
UUID=792fd0e5-0942-45cc-b07b-400213890a85 /var/cache/pacman/pkg btrfs subvol=/@var-cache-pacman-pkg,defaults,noatime,space_cache,noautodefrag,compress=lzo 0 2
UUID=792fd0e5-0942-45cc-b07b-400213890a85 /swap btrfs subvol=@swap,defaults,compress=no 0 0
/swap/swapfile none swap defaults 0 0
UUID=27454cca-524b-4918-afa5-9ae9dbb2d1ee /mnt/storage ext4 defaults,noatime 0 2
