Hmm. I’m looking back at my pacman.log on this specifically, and seeing this in a couple places:
[2025-09-25T21:21:14-0400] [ALPM-SCRIPTLET] Error! Bad return status for module build on kernel: 6.12.48-1-lts (x86_64)
[2025-09-25T21:21:14-0400] [ALPM-SCRIPTLET] Consult /var/lib/dkms/tflight4/1.0/build/make.log for more information.
[2025-09-25T21:21:14-0400] [ALPM-SCRIPTLET] ==> WARNING: `dkms install --no-depmod tflight4/1.0 -k 6.12.48-1-lts' exited 10
[2025-09-25T21:21:14-0400] [ALPM-SCRIPTLET] ==> dkms install --no-depmod v4l2loopback/0.15.1 -k 6.16.9-1-cachyos
[2025-09-25T21:21:16-0400] [ALPM-SCRIPTLET] ==> dkms install --no-depmod v4l2loopback/0.15.1 -k 6.16.8-arch3-1
[2025-09-25T21:21:19-0400] [ALPM-SCRIPTLET] ==> dkms install --no-depmod openrazer-driver/3.10.3 -k 6.16.8-zen3-1-zen
[2025-09-25T21:21:27-0400] [ALPM-SCRIPTLET] ==> dkms install --no-depmod vboxhost/7.2.2_OSE -k 6.12.48-1-lts
[2025-09-25T21:21:31-0400] [ALPM-SCRIPTLET] ==> dkms install --no-depmod tflight4/1.0 -k 6.16.8-zen3-1-zen
[2025-09-25T21:21:31-0400] [ALPM-SCRIPTLET] Deprecated feature: CLEAN (/var/lib/dkms/tflight4/1.0/source/dkms.conf)
[2025-09-25T21:21:32-0400] [ALPM-SCRIPTLET]
[2025-09-25T21:21:32-0400] [ALPM-SCRIPTLET] Error! Bad return status for module build on kernel: 6.16.8-zen3-1-zen (x86_64)
[2025-09-25T21:21:32-0400] [ALPM-SCRIPTLET] Consult /var/lib/dkms/tflight4/1.0/build/make.log for more information.
[2025-09-25T21:21:32-0400] [ALPM-SCRIPTLET] ==> WARNING: `dkms install --no-depmod tflight4/1.0 -k 6.16.8-zen3-1-zen' exited 10
[2025-09-25T21:21:32-0400] [ALPM-SCRIPTLET] ==> dkms install --no-depmod openrazer-driver/3.10.3 -k 6.12.48-1-lts
[2025-09-25T21:21:39-0400] [ALPM-SCRIPTLET] ==> dkms install --no-depmod vboxhost/7.2.2_OSE -k 6.16.8-zen3-1-zen
[2025-09-25T21:21:43-0400] [ALPM-SCRIPTLET] ==> dkms install --no-depmod vboxhost/7.2.2_OSE -k 6.16.8-arch3-1
[2025-09-25T21:21:48-0400] [ALPM-SCRIPTLET] ==> depmod 6.16.9-1-cachyos
[2025-09-25T21:21:49-0400] [ALPM-SCRIPTLET] ==> depmod 6.16.8-arch3-1
[2025-09-25T21:21:51-0400] [ALPM-SCRIPTLET] ==> depmod 6.12.48-1-lts
[2025-09-25T21:21:51-0400] [ALPM-SCRIPTLET] ==> depmod 6.16.8-zen3-1-zen
[2025-09-25T21:21:52-0400] [ALPM] running '90-dracut-install.hook'...
[2025-09-25T21:21:53-0400] [ALPM-SCRIPTLET] :: Building initramfs for linux-lts (6.12.48-1-lts)
[2025-09-25T21:22:10-0400] [ALPM-SCRIPTLET] :: Building fallback initramfs for linux-lts (6.12.48-1-lts)
[2025-09-25T21:22:11-0400] [ALPM-SCRIPTLET] Failed to add dependency on unit: Unit initrd.target does not exist
[2025-09-25T21:22:32-0400] [ALPM-SCRIPTLET] :: Building initramfs for linux (6.16.8-arch3-1)
[2025-09-25T21:22:49-0400] [ALPM-SCRIPTLET] :: Building fallback initramfs for linux (6.16.8-arch3-1)
[2025-09-25T21:22:50-0400] [ALPM-SCRIPTLET] Failed to add dependency on unit: Unit initrd.target does not exist
[2025-09-25T21:23:09-0400] [ALPM-SCRIPTLET] :: Building initramfs for linux-zen (6.16.8-zen3-1-zen)
[2025-09-25T21:23:27-0400] [ALPM-SCRIPTLET] :: Building fallback initramfs for linux-zen (6.16.8-zen3-1-zen)
[2025-09-25T21:23:27-0400] [ALPM-SCRIPTLET] Failed to add dependency on unit: Unit initrd.target does not exist
[2025-09-25T21:23:47-0400] [ALPM-SCRIPTLET] :: Building initramfs for linux-cachyos (6.16.9-1-cachyos)
[2025-09-25T21:24:04-0400] [ALPM-SCRIPTLET] :: Building fallback initramfs for linux-cachyos (6.16.9-1-cachyos)
[2025-09-25T21:24:05-0400] [ALPM-SCRIPTLET] Failed to add dependency on unit: Unit initrd.target does not exist
And actually continuing on from that just a few more seemingly out of the blue:
[2025-09-25T21:24:24-0400] [ALPM] running 'code-marketplace.hook'...
[2025-09-25T21:24:24-0400] [ALPM] running 'dbus-reload.hook'...
[2025-09-25T21:24:24-0400] [ALPM] running 'detect-old-perl-modules.hook'...
[2025-09-25T21:24:25-0400] [ALPM] running 'eos-reboot-required.hook'...
[2025-09-25T21:24:26-0400] [ALPM] running 'ghc-register.hook'...
[2025-09-25T21:24:29-0400] [ALPM] running 'gio-querymodules.hook'...
[2025-09-25T21:24:29-0400] [ALPM] running 'glib-compile-schemas.hook'...
[2025-09-25T21:24:29-0400] [ALPM] running 'gtk-update-icon-cache.hook'...
[2025-09-25T21:24:29-0400] [ALPM] running 'gtk4-querymodules.hook'...
[2025-09-25T21:24:29-0400] [ALPM] running 'rebuild-detector.hook'...
[2025-09-25T21:24:39-0400] [ALPM-SCRIPTLET] foreign firestorm-bin
[2025-09-25T21:24:39-0400] [ALPM-SCRIPTLET] aur qt5-base
[2025-09-25T21:24:39-0400] [ALPM] running 'texinfo-install.hook'...
[2025-09-25T21:24:40-0400] [ALPM] running 'update-desktop-database.hook'...
[2025-09-25T21:24:40-0400] [ALPM] running 'update-vlc-plugin-cache.hook'...
[2025-09-25T21:24:40-0400] [ALPM] running 'vscodium-marketplace.hook'...
[2025-09-25T21:24:40-0400] [ALPM] running 'zz-snap-pac-post.hook'...
[2025-09-25T21:24:40-0400] [ALPM-SCRIPTLET] ==> root: 1039
[2025-09-25T21:24:40-0400] [ALPM] running 'zz-snap-pac-postz-grub.hook'...
[2025-09-25T21:24:40-0400] [ALPM-SCRIPTLET] Generating grub configuration file ...
[2025-09-25T21:24:41-0400] [ALPM-SCRIPTLET] Found theme: /boot/grub/themes/fallout-grub-theme/theme.txt
[2025-09-25T21:24:41-0400] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-linux-zen
[2025-09-25T21:24:41-0400] [ALPM-SCRIPTLET] Found initrd image: /boot/initramfs-linux-zen.img
[2025-09-25T21:24:41-0400] [ALPM-SCRIPTLET] Found fallback initrd image(s) in /boot: initramfs-linux-zen-fallback.img
[2025-09-25T21:24:41-0400] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-linux-zen.old
[2025-09-25T21:24:41-0400] [ALPM-SCRIPTLET] Found initrd image: /boot/initramfs-linux-zen.img.old
[2025-09-25T21:24:41-0400] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-linux-lts
[2025-09-25T21:24:41-0400] [ALPM-SCRIPTLET] Found initrd image: /boot/initramfs-linux-lts.img
[2025-09-25T21:24:41-0400] [ALPM-SCRIPTLET] Found fallback initrd image(s) in /boot: initramfs-linux-lts-fallback.img
[2025-09-25T21:24:41-0400] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-linux-lts.old
[2025-09-25T21:24:41-0400] [ALPM-SCRIPTLET] Found initrd image: /boot/initramfs-linux-lts.img.old
[2025-09-25T21:24:41-0400] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-linux-cachyos
[2025-09-25T21:24:41-0400] [ALPM-SCRIPTLET] Found initrd image: /boot/initramfs-linux-cachyos.img
[2025-09-25T21:24:41-0400] [ALPM-SCRIPTLET] Found fallback initrd image(s) in /boot: initramfs-linux-cachyos-fallback.img
[2025-09-25T21:24:41-0400] [ALPM-SCRIPTLET] Found initrd image: /boot/initramfs-linux.img
[2025-09-25T21:24:41-0400] [ALPM-SCRIPTLET] Found fallback initrd image(s) in /boot: initramfs-linux-fallback.img
[2025-09-25T21:24:41-0400] [ALPM-SCRIPTLET] Warning: os-prober will not be executed to detect other bootable partitions.
[2025-09-25T21:24:41-0400] [ALPM-SCRIPTLET] Systems on them will not be added to the GRUB boot configuration.
[2025-09-25T21:24:41-0400] [ALPM-SCRIPTLET] Check GRUB_DISABLE_OS_PROBER documentation entry.
[2025-09-25T21:24:41-0400] [ALPM-SCRIPTLET] Adding boot menu entry for UEFI Firmware Settings ...
And then the shapshot listing shows up before it’s all said and done.
I’m not following. Quiet output set on what? dracut? (seeings I can see this on dracut-rebuild without pacman/paru being involved, I can easily repeat this).
Nice. So this will ultimately be fixed in dracut in the coming… Well, whenever until the next actual release pushes out, then to repos, and… Onwards.
I was curious because I kept seeing it, and yes, I noted it was “not a problem”, but still seeing it, in my boot process building system, still after months, was starting to concern me. LOL
