Would appreciate very much for any help, if possible.
I have an external SSD drive (Sandisk Extreme 500 GB) on which I had a folder with more than 100 GB. So, I deleted this folder, but its used space is being wrongly reported.
The system says that the used space on this drive is around 100 GB more than I expected (it displays 418 GB).
And also df -h reports this wrong total used space, while Nautilus, for example, reports the correct used space if I select all files on drive and go to properties (308 GB).
So, I can´t imagine how could I illustrate this with screenshots.
But, for example. I am displaying hidden folders inside that drive, through Nautilus. If I select all the folders there, including that very small .Trash-1000, I get a total used of 308 GB.
And at terminal I get 418 GB used for that same place, with df -h.
So, there’s around 110 GB “lost”. Also, I could not fine large files inside .Trash-1000, just a couple of very small ones.
