Ethernet problem
The cable is blinking, and yet still no connection.
inxi
There’s similar topic, see if it helps.
i did modprobe r8169
then systemctl restart NetworkManager, and it worked
but my problem is i have to do this every boot, is there a way to make this permanent?
Welcome to the forum @tasroboy :enos: :enos_flag: :partying_face:
Try removing r8168 with
sudo pacman -R r8168
As told by @kjw, you need to remove the r8168. It is one of the steps in the shared topic, which solved that issue.
it worked thanks!
