Ethernet not working on Dell Latitude 7480
Wifi works, but ethernet is a no go. Im not sure where to start. Can someone help me? :slight_smile:
inxi -Naz —> https://discovery.endeavouros.com/forum-log-tool-options/how-to-include-systemlogs-in-your-post/2021/03/
Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d7 class-ID: 0200
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24f3 class-ID: 0280
Device-3: Intel driver: N/A pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A
bus-ID: 03:00.0 chip-ID: 8086:093c class-ID: 0280
Would be helpful to see more about the hardware:
inxi -Fza | eos-sendlog
and show the returned address here.
ethernet is may disabled in Bios? → Advanced → Integrated NIC
It is enabled in the BIOS
bash: eos-sendlog: command not found
Are you using Arch? Or have you removed EndeavourOS apps?
I didn’t install the apps, I can if needed. What package is it?
@ZippyDippy, in terminal run inxi -S and post back the output.
pacman  -Qo /usr/bin/eos-sendlog
/usr/bin/eos-sendlog is owned by eos-bash-shared 25.6.2-1
Host: noneofyourbusiness Kernel: 6.15.6-arch1-1 arch: x86_64 bits: 64
Desktop: KDE Plasma v: 6.4.2 Distro: EndeavourOS
Is this just a sanity check to make sure im using EOS? :upside_down_face:
Partly. :rofl:
Just odd that nxi -Fza | eos-sendlog bash: eos-sendlog: command not found was the output.
Reinstalling fixed the issue. I never changed anything, it just worked the second time around. Just the usual linux problems I guess. :melting_face:
May untag one package too much on the previous attempt :wink:
But indeed it can happen something got not installed correctly in rare cases, installer still can not be 100%
