Ethernet is fuzzy
Ethernet not reconnecting after suspend. modprobe -r r8168 then modprobe -i r8168 allows for re-connection after resume.
I believe this should not be happening. May be wrong but I wish I did not have to do those to reconnect to the internet.
Any ideas ?
An idea, would TLP be causing this problem ?
Thanks. Ran with the workaround and now using r8169. Will report back if still with issue…
