Similar, however I’m using ext4 and there is no fails and my system boots normally
I assume “SEQUENCE-OF-NUMBERS” is your root device /dev/mapper/luks-7ea9d4b6-fc37-49ea-9b87-780b0e3a45f4?
Maybe run a fsck on that device after booting.
Those are clearly not the same.
Well the last quote shows the output with the swapfile installation, the previous one is with the partition
After installing vanilla Arch, I was getting the same output during system boot so I guess it’s pretty normal and doesn’t affect my PC usage at all. @2000 you’re right, I’ll probably start using swapfile instead of partitions in the future. Thanks everyone for the help and thank you Johannes for an amazing i3 config!
As I hinted, your root device is getting checked at boot. If this happens every boot you definitely should check and maybe repair the device.
Also check if a /forcefsck file exists on your system; if yes, remove it.
