Error while browsing mobile device with kde connect
When opened the Internal and SD memory of my mobile from dolphin with kde connect
getting error like:
Error when accessing filesystem. sshfs finished with exit code 1.
Did you see this?
How to downgrade a package?
downgrade openssh
If you don’t have downgrade installed, install it with:
sudo pacman -S downgrade
Thanks that worked.
I was posting a lot of questions in a days, is that against forum rules.
Not unless it becomes extreme or you are posting the same questions over and over again.
