swapfile
with swap partition I habe never problems so far
swapfile
[ricklinux@eos-kde ~]$ cat /etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=5884-DB29 /boot/efi vfat defaults,noatime 0 2
UUID=9a129d8f-481d-43b6-967f-5d7016ae368f / btrfs subvol=/@,defaults,noatime,compress=zstd 0 0
UUID=9a129d8f-481d-43b6-967f-5d7016ae368f /home btrfs subvol=/@home,defaults,noatime,compress=zstd 0 0
UUID=9a129d8f-481d-43b6-967f-5d7016ae368f /var/cache btrfs subvol=/@cache,defaults,noatime,compress=zstd 0 0
UUID=9a129d8f-481d-43b6-967f-5d7016ae368f /var/log btrfs subvol=/@log,defaults,noatime,compress=zstd 0 0
UUID=9a129d8f-481d-43b6-967f-5d7016ae368f /swap btrfs subvol=/@swap,defaults,noatime 0 0
/swap/swapfile swap swap defaults 0 0
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
Just remove it.
I have it also too:
/swap/swapfile none swap defaults 0 0
I just tested an no problems here.
I suspect there is something wrong with your swapfile itself. I would delete it and recreate it.
I thought if you were going to make a new one anyways. As mentioned before, it looks like something is wrong with the swapfile itself. That is why swapon/swapoff errors out I guess and it fails to get activated at boot. Of course it is up to you if you want to do away with it altogether or …
Is it just this command to remove it?
rm /swap/swapfile
Yes, with sudo ![]()
If your swapfile is working, why would you remove it?
Just going by this? @anon50380917 swapfile isn’t working? ![]()
But you are not having any issues with yours.
Or don’t you like swapfiles?
I didn’t remove mine. I just asked if that was the command to do it? ![]()
Edit: I just turned mine off and enlarged it to see if there was any problem because @anon50380917 stated it was since 6.14 kernel?
I think if it gets removed and recreated the problem will be gone. It’s not a bug in kde. ![]()
Another one of the great features of Knome then? ![]()
I have now decided to set up a swap partition again. There is enough space available. I am too old for this shit … ![]()
Why do you want a swap partition instead of the swap file? I haven’t had any issues with swapfile on btrfs. The issue you had with it not working is minor and easily fixed.
Because it just works … when I have more time and desire, I deal with it again.
In addition: from easy to fix could probably not be the speech here.
The only thing that has always bothered me with the automatic installation with the swap partition is the fact that , although Swap without hibernation was selected, it was still activated. Needs no one …
Edit: I will probably start another attempt in the coming week.
Perfected D-english - davon kann nicht die Rede sein.
Perfected D-english, again - das braucht kein Mensch!
Denglish made by DeepL ![]()
To get in indicator if the file is really a swapfile I would do
sudo file /swap/swapfile
It is easy enough to recreate a swapfile
sudo su -
rm /swap/swapfile
btrfs filesystem mkswapfile -s 1g /swap/swapfile # adjust the size to your liking
