Error in installation: Can't mount BTRS partition
https://termbin.com/8h8i
That’s from the installation log.
On the terminal, here’s the error:
Running ("mount", "-t", "btrfs", "/dev/nvme0n1p2", "/tmp/calamares-root-d9lpotlu/")
    ..  Target cmd: ("mount", "-t", "btrfs", "/dev/nvme0n1p2", "/tmp/calamares-root-d9lpotlu/") Exit code: 32 output:
 mount: /tmp/calamares-root-d9lpotlu: unknown filesystem type 'btrfs'.
    ..  Running ("udevadm", "settle")
    ..  Running ("sync")
WARNING: [PYTHON JOB]: "Cannot mount /dev/nvme0n1p2"
Any ideas how to fix this?
Please use code tags when posting info from the terminal. I’m not the btrfs expert although i am running it also. There is a brand new ISO just posted now!
Edit Does it boot to a tty?
New ISO did fix it!
@omcantu
Welcome to EndeavourOS!
