I have the EOS-update-notifier set to tray and it shows up when there are updates, however when clicking the icon, no matter how, it opens the updater and the icon that drops into position when the EOS-update-notifier one disappears. So two apps open for the one click. It is not a major problem just an annoyance and possibly an easy fix.
Kernel: 5.11.11-arch1-1 x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-linux
root=UUID=da7b12a4-11a6-4908-a3a4-a2d85deddd58 rw quiet nvidia-drm.modeset=1
resume=UUID=41a6a83a-6dba-4316-a745-d453b5ab8261 loglevel=3 nowatchdog
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: EndeavourOS base: Arch Linux
Type: Desktop Mobo: Gigabyte model: GA-78LMT-USB3 R2 v: sex serial: <filter>
BIOS: Award v: F1 date: 11/08/2017
Info: 8-Core model: AMD FX-8350 bits: 64 type: MCP arch: Bulldozer
family: 15 (21) model-id: 2 stepping: N/A microcode: 6000852 L2 cache: 2 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 64450
Speed: 1690 MHz min/max: 1400/4000 MHz boost: enabled Core speeds (MHz):
1: 1690 2: 1491 3: 1406 4: 1631 5: 1412 6: 1404 7: 1409 8: 1405
Vulnerabilities: Type: itlb_multihit status: Not affected
Type: spec_store_bypass
mitigation: Speculative Store Bypass disabled via prctl and seccomp
Type: spectre_v1
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP:
disabled, RSB filling
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: Gigabyte
driver: nvidia v: 460.67 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1c03 class ID: 0300
Display: x11 server: X.Org 1.20.10 driver: loaded: nvidia display ID: :0.0
screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3")
s-diag: 583mm (23")
Monitor-1: DVI-D-0 res: 1920x1080 hz: 60 dpi: 102
size: 480x270mm (18.9x10.6") diag: 551mm (21.7")
OpenGL: renderer: GeForce GTX 1060 6GB/PCIe/SSE2 v: 4.6.0 NVIDIA 460.67
direct render: Yes
Device-1: AMD SBx00 Azalia vendor: Gigabyte driver: snd_hda_intel v: kernel
bus ID: 00:14.2 chip ID: 1002:4383 class ID: 0403
Device-2: NVIDIA GP106 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:10f1
class ID: 0403
Sound Server: ALSA v: k5.11.11-arch1-1
vendor: Gigabyte driver: r8168 v: 8.048.03-NAPI modules: r8169 port: ce00
bus ID: 03:00.0 chip ID: 10ec:8168 class ID: 0200
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 2.94 TiB used: 107.65 GiB (3.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: TeamGroup model: T253LE240G
size: 223.57 GiB block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
rotation: SSD serial: <filter> rev: 61.2 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 830 Series
size: 476.94 GiB block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
rotation: SSD serial: <filter> rev: 3B1Q scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Toshiba model: DT01ACA200
size: 1.82 TiB block size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: ABB0 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 vendor: SanDisk model: SSD PLUS 480GB
size: 447.13 GiB block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
rotation: SSD serial: <filter> rev: 04RL scheme: MBR
ID-1: / raw size: 109.76 GiB size: 107.48 GiB (97.92%)
used: 38.2 GiB (35.5%) fs: ext4 dev: /dev/sdd1 maj-min: 8:49
ID-2: /home raw size: 335.37 GiB size: 329.11 GiB (98.13%)
used: 69.44 GiB (21.1%) fs: ext4 dev: /dev/sdd5 maj-min: 8:53
Kernel: swappiness: 60 (default) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 2 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdd2 maj-min: 8:50
System Temperatures: cpu: 17.4 C mobo: N/A
Fan Speeds (RPM): N/A
Processes: 233 Uptime: 1h 53m wakeups: 21 Memory: 15.61 GiB
used: 1.61 GiB (10.3%) Init: systemd v: 248 Compilers: gcc: 10.2.0
clang: 11.1.0 Packages: pacman: 1059 lib: 316 Shell: Bash v: 5.1.4
running in: xfce4-terminal inxi: 3.3.01
