EOS unresponsive after logging in
Hello, I am new to EOS and I have been running into an issue where after I boot into my system and log in gnome and the computer itself is unresponsive, keyboard shortcuts don’t work and so does clicking. I decided to reinstall fresh because of this but the issue persists.
[EDIT]: Here is my system info.
Summary
Kernel: 6.6.7-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1 Console: tty 4 DM: GDM
Type: Laptop System: LENOVO product: 81D6 v: Lenovo ideapad 330-15AST
serial: Chassis: type: 10 v: Lenovo ideapad 330-15AST
serial:
Mobo: LENOVO model: LNVNB161216 v: SDK0J40700WIN serial: UEFI: LENOVO
v: 8UCN19WW date: 05/14/2021
Battery:
ID-1: BAT0 charge: 15.7 Wh (99.4%) condition: 15.8/30.6 Wh (51.6%) volts: 8.3 min: 7.6
model: CPT-COS L16C2PB2 serial: status: not charging
Info: dual core model: AMD A9-9425 RADEON R5 5 COMPUTE CORES 2C+3G bits: 64 type: MCP
arch: Excavator rev: 0 cache: L1: 192 KiB L2: 2 MiB
Speed (MHz): avg: 1600 high: 1800 min/max: 1400/3100 boost: enabled cores: 1: 1800 2: 1400
bogomips: 12405
Device-1: AMD Stoney [Radeon R2/R3/R4/R5 Graphics] vendor: Lenovo driver: amdgpu v: kernel
arch: GCN-3 ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:01.0 chip-ID: 1002:98e4
Device-2: IMC Networks EasyCamera driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
bus-ID: 1-1.3:4 chip-ID: 13d3:5a02
Display: server: X.org v: 1.21.1.10 with: Xwayland v: 23.2.3 compositor: gnome-shell driver:
gpu: amdgpu note: X driver n/a, try sudo/root tty: 170x48
Monitor-1: eDP-1 model: ChiMei InnoLux 0x15db res: 1366x768 dpi: 101 diag: 394mm (15.5")
API: EGL v: 1.5 platforms: device: 0 drv: radeonsi device: 1 drv: swrast surfaceless:
drv: radeonsi inactive: gbm,wayland,x11
API: OpenGL v: 4.5 vendor: mesa v: 23.2.1-arch1.2 note: console (EGL sourced) renderer: AMD
Radeon R5 Graphics (stoney LLVM 16.0.6 DRM 3.54 6.6.7-arch1-1), llvmpipe (LLVM 16.0.6 256
bits)
Device-1: AMD vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:01.1 chip-ID: 1002:15b3
Device-2: AMD Family 15h Audio vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:09.2
chip-ID: 1022:157a
API: ALSA v: k6.6.7-arch1-1 status: kernel-api
Server-1: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse status: active
2: wireplumber status: active 3: pipewire-alsa type: plugin 4: pw-jack type: plugin
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter vendor: Lenovo
driver: rtw_8821ce v: N/A pcie: speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 01:00.0
chip-ID: 10ec:c821
IF: wlan0 state: up mac:
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Lenovo driver: r8169 v: kernel
pcie: speed: 2.5 GT/s lanes: 1 port: 1000 bus-ID: 02:00.0 chip-ID: 10ec:8136
IF: enp2s0 state: down mac:
Bluetooth:
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 bus-ID: 1-1.2:3 chip-ID: 0bda:c024
Report: btmgmt ID: hci0 rfk-id: 2 state: down bt-service: disabled rfk-block: hardware: no
software: yes address: N/A
Local Storage: total: 931.51 GiB used: 8.46 GiB (0.9%)
ID-1: /dev/sda vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB speed: 6.0 Gb/s
serial:
ID-1: / size: 244.03 GiB used: 8.46 GiB (3.5%) fs: ext4 dev: /dev/sda7
ID-2: /boot/efi size: 1022 MiB used: 444 KiB (0.0%) fs: vfat dev: /dev/sda4
System Temperatures: cpu: 31.6 C mobo: N/A gpu: amdgpu temp: 31.0 C
Fan Speeds (rpm): N/A
Processes: 160 Uptime: 7m Memory: total: 8 GiB note: est. available: 6.67 GiB
used: 827.9 MiB (12.1%) Init: systemd v: 255 default: graphical Compilers: gcc: 13.2.1
Packages: 887 pm: pacman pkgs: 882 pm: flatpak pkgs: 5 Shell: Bash v: 5.2.21 running-in: tty 4
inxi: 3.3.31
Hello @Mamadough
Are there any
gnome-extensions list --enabled
Sorry for being late,
The command doesn’t return anything from the tty terminal. I assume it’s because none are enabled
