The eos specific ones from my understanding are not needed, they just help makes the post install a lot quicker but if they are broke don’t use and let whoever managing the repo know
Because of this, which is my initial question, why isnt i3 on the list?
Looking at the date of the profiles file , it has been created on december 2024, guess something is a bit out of sync here.
Line 22
Just noticed the s at the end of packgelsit here
Could that be the issue (sooriy for the typos getting tiyred)
is this the same link/list
Edit yer it is but are we adding the s at the end of the prompt?
I may be wrong here but I think i3 is one of the editions we are removing as we don’t have a real maintainer for that WM anymore. That may be why its not in the list anymore.Note other WM/DE’s are also gone (Openbox, LXDE)
eos-packagelist --list
Desktop-Base + Common packages
EndeavourOS applications
Recommended applications selection
Firefox and language package
Spell Checker and language package
Firewall
LTS kernel in addition
Printing support
HP printer/scanner support
KDE-Desktop
GNOME-Desktop
XFCE4-Desktop
Cinnamon-Desktop
COSMIC-Desktop
Budgie-Desktop
LXQT-Desktop
Sway-Window-Manager
Yer I think you may be onto something, the slides I made did not include i3
The eos-packagelist tool reads from eos calamares repo, and this holds the latest development, for upcoming release of the ISO.
No way to install legacy options with eos-packagelist. You have to use the manual way, info on that is in the Readme
Now who read what they use these days ![]()
I am only after the list of packages installed with i3, not to reinstall them
However, if i3 is going to be dropped then I will work from another baseline EOS installation other than i3
What is the time frame for dropping i3?
If that is soon then I am going to rethink my project to do an EOS installation and then write a script to change it to my ArchLabs set-up, as in which EOS installation I use as a baseline.
read the readme @joekamprad posted
the TLDR is that it is already removed.
That’s my understanding,too.
As a long-time i3 fan, I was initially bummed out when I learned this. I even considered volunteering to take on the i3 maintenance task.
After all, I had tried sway on several occasions (pitched as an i3 drop-in replacement) and kept finding a series of minor irritants that, taken together, made me return to i3.
But then I finally stopped complaining to myself and bit the bullet. I spent more time with sway (wayland) and discovered a solid solution to each and every issue that bothered me.
As such, the combined result (especially having customized waybar to my liking) actually now feels superior to anything I ever had running with i3. There’s not a single app/function in i3 that I can’t deploy as well in sway.
And so, as a daily driver convert to sway, I haven’t touched i3 in quite a while. Kind of glad I didn’t take on the i3 maintenance responsibility. ![]()
To my fellow i3-users, I suggest you spend some serious time with sway. I’d be happy to offer suggestions if you hit a snag or two. The available documentation is good. And wayland is slowly but surely becoming the “next thing” linux users will need to embrace over time. Onward.
Is your issue more related to setting it up then? The DE/WM updates happen EOS just configures it all a bit.
Perhaps look at a similar setup to mine (I use KDE but have Openbox there for a backup) install i3 and configure it to work with what you have?
There is also no-desktop install option. It will work as baseline for what ever you want to install as Desktop environment.
Eos-i3 also have a way to manually install it.
And we have two options inside installer to add a list of packages to get installed and even full setup scripts. like this for i3: https://github.com/endeavouros-team/endeavouros-i3wm-setup/blob/main/i3_install_isomode
old pic/iso but yes if you tick/select No Desktop it will not install any but all the rest will be set up the EndeavourOS way. Its made to tinker ![]()
That’s EXACTLY what I want, a base install of EOS ![]()
Just a couple of questions about your links:
- Tutorial to install EndeavourOS-i3wm-setup from scratch - For installing it later on, in case if you have installed another DE on initial install from the ISO
Are there any extra steps needed for installing i3 from a ‘No Desktop’ EOS installation rather than after installing another DE? I think I need to set up my xdg user directories, for example? any other things that will be missing?
- Could you tell me the difference between i3_install & i3_install_isomode scripts (in terms in when they are applicable etc) please?
a guess from what I see but 1 for a fresh install and will setup user also and other to install besides/ after (could be wrong) but yer shoudl be able to easilty installl add, what I would also do is check the packgelist to see what is being installed and remove what is not needed
