Eos-pacdiff Pacdiff & meld from eos-welcome problem
Hey,
I’m pretty sure it was working as intended before on this “fresh” install (could it be last eos-welcome update related?) but when I launch pacdiff & meld from the welcome app here’s what happens:
Starting pacdiff & meld as root ...
[sudo]:
sudo: unable to execute /tmp/tmp.wwyYgzCbQB: Permission denied
It launches fine for me. Have you been doing something with permissions? :scream_cat:
==> pacnew file found for /etc/pacman.d/endeavouros-mirrorlist
:: (V)iew, (M)erge, (S)kip, (R)emove pacnew, (O)verwrite with pacnew, (Q)uit: [v/m/s/r/o/q]
not at all, I barely touched anything on that install :cry:
if I do
$ sudo pacdiff
==> ERROR: Cannot find the vim -d binary required for viewing differences.
I don’t even know what the default text editor is (I chose to install KDE for the first time here)
I never run pacdiff without going through eos-welcome btw :sweat_smile:
I wish i could help but I don’t know what would be the problem. :thinking:
Edit: Mine shows the same for that command.
[ricklinux@rick-ms7c37 ~]$ sudo pacdiff
So someone more knowledgeable such as @manuel would need to answer this.
is your eos-welcome up to date ?
As far as i know. My system is continually updated.
Edit:
[ricklinux@rick-ms7c37 ~]$ eos-welcome --version
24.6-1
I use pacdiff -s (without sudo) and I have no problem.
what about eos-pacdiff?
That seems to be the ticket…
[wombat@endeavouros ~]$ sudo pacdiff
[sudo] password for wombat:
[wombat@endeavouros ~]$ pacdiff -s
[wombat@endeavouros ~]$ eos-pacdiff
==> reading /etc/eos-pacdiff.conf
NOTE: eos-pacdiff is a powerful tool, so use it carefully!
For example, please do not modify files like:
    /etc/passwd
    /etc/group
    /etc/shadow
and related files unless you know exactly what you are doing.
You can remove this warning popup by changing the value of
variable EOS_PACDIFF_WARNING in file /etc/eos-script-lib-yad.conf.
(Note that you may need to merge the changes from
file /etc/eos-script-lib-yad.conf.pacnew first!)
Gtk-Message: 12:53:45.962: Failed to load module "appmenu-gtk-module"
I don’t need it, I launch pacdiff after updating, my update script run these commands.
yay -Syu --repo
yay -Fy
yay -Qnq > ~/pkglist-repo.txt
pacdiff -s
so it’s working for you too,
I clearly have a problem messing with eos-pacdiff then
@manuel ? any clue
I just see this and will check…
Mine works with eos-pacdiff also. :wink:
i just updated system and it is working as before.
This only say vim is not installed and there is no other editor set to be used…
So @manuel can do what ever he was doing, no need for interventions here :beers:
ls -l /tmp/tmp.wwyYgzCbQB
will show permissions and rights…
I forgot that my DIFFPROG is set in /etc/environment, maybe it’s why I don’t see this “vim -d” message.
Maybe some updates are missing?
Please do
sudo pacman -Syu eos-bash-shared
eos-pacdiff
Does that help?
sudo pacman -Syu eos-bash-shared eos-pacdiff
$ sudo pacman -Syu eos-bash-shared
eos-pacdiff
:: Synchronisation des bases de données de paquets…
 endeavouros est à jour
 core                                  120,8 KiB   171 KiB/s 00:01 [------------------------------------] 100%
 extra                                   7,9 MiB  1472 KiB/s 00:05 [------------------------------------] 100%
 multilib                              138,4 KiB   172 KiB/s 00:01 [------------------------------------] 100%
avertissement : eos-bash-shared-24.16.11-1 est à jour -- réinstallation
:: Début de la mise à jour complète du système…
résolution des dépendances…
recherche des conflits entre paquets…
Paquet (67)                  Ancienne version  Nouvelle version  Changement net  Taille du téléchargement
extra/attica                 6.2.0-1           6.3.0-1                -0,03 MiB                  0,72 MiB
extra/baloo                  6.2.0-1           6.3.0-1                 0,03 MiB                  0,66 MiB
extra/bluez-qt               6.2.0-1           6.3.0-1                -0,12 MiB                  0,91 MiB
extra/breeze-icons           6.2.0-1           6.3.0-1                 2,10 MiB                  7,78 MiB
core/fakeroot                1.34-1            1.35-1                  0,01 MiB                  0,07 MiB
extra/frameworkintegration   6.2.0-1           6.3.0-1                 0,00 MiB                  0,07 MiB
extra/karchive               6.2.0-1           6.3.0-1                 0,00 MiB                  0,41 MiB
extra/kauth                  6.2.0-1           6.3.0-1                 0,00 MiB                  0,28 MiB
extra/kbookmarks             6.2.0-1           6.3.0-1                -0,07 MiB                  0,34 MiB
extra/kcmutils               6.2.0-1           6.3.0-1                -0,05 MiB                  0,42 MiB
extra/kcodecs                6.2.0-1           6.3.0-1                 0,01 MiB                  0,35 MiB
extra/kcolorscheme           6.2.0-1           6.3.0-1                 0,00 MiB                  0,19 MiB
extra/kcompletion            6.2.0-1           6.3.0-1                -0,12 MiB                  0,46 MiB
extra/kconfig                6.2.0-1           6.3.0-1                 0,37 MiB                  1,33 MiB
extra/kconfigwidgets         6.2.0-1           6.3.0-1                -0,09 MiB                  0,65 MiB
extra/kcontacts              1:6.2.0-1         1:6.3.0-1               0,17 MiB                  0,85 MiB
extra/kcoreaddons            6.2.0-1           6.3.0-1                -0,02 MiB                  1,20 MiB
extra/kcrash                 6.2.0-1           6.3.0-1                 0,01 MiB                  0,13 MiB
extra/kdbusaddons            6.2.0-1           6.3.0-1                -0,01 MiB                  0,19 MiB
extra/kdeclarative           6.2.0-1           6.3.0-1                 0,00 MiB                  0,27 MiB
extra/kded                   6.2.0-1           6.3.0-1                 0,00 MiB                  0,06 MiB
extra/kdesu                  6.2.0-1           6.3.0-1                 0,01 MiB                  0,24 MiB
extra/kdnssd                 6.2.0-1           6.3.0-1                -0,03 MiB                  0,27 MiB
extra/kfilemetadata          6.2.0-1           6.3.0-1                 0,01 MiB                  0,49 MiB
extra/kglobalaccel           6.2.0-1           6.3.0-1                 0,00 MiB                  0,21 MiB
extra/kguiaddons             6.2.0-1           6.3.0-1                -0,04 MiB                  0,35 MiB
extra/kholidays              1:6.2.0-1         1:6.3.0-1               0,01 MiB                  0,42 MiB
extra/ki18n                  6.2.0-1           6.3.0-1                 0,00 MiB                  1,89 MiB
extra/kiconthemes            6.2.0-1           6.3.0-1                -0,03 MiB                  0,49 MiB
extra/kidletime              6.2.0-1           6.3.0-1                 0,00 MiB                  0,16 MiB
extra/kimageformats          6.2.0-1           6.3.0-1                 0,00 MiB                  0,23 MiB
extra/kio                    6.2.0-2           6.3.0-1                -1,08 MiB                  5,33 MiB
extra/kirigami               6.2.1-1           6.3.0-1                 0,23 MiB                  1,14 MiB
extra/kitemmodels            6.2.0-1           6.3.0-1                -0,08 MiB                  0,51 MiB
extra/kitemviews             6.2.0-1           6.3.0-1                -0,16 MiB                  0,32 MiB
extra/kjobwidgets            6.2.0-1           6.3.0-1                -0,03 MiB                  0,28 MiB
extra/knewstuff              6.2.0-1           6.3.0-1                 0,08 MiB                  0,92 MiB
extra/knotifications         6.2.0-1           6.3.0-1                -0,01 MiB                  0,29 MiB
extra/knotifyconfig          6.2.0-1           6.3.0-1                -0,02 MiB                  0,16 MiB
extra/kpackage               6.2.0-1           6.3.0-1                 0,01 MiB                  0,32 MiB
extra/kparts                 6.2.0-1           6.3.0-1                -0,09 MiB                  0,47 MiB
extra/kpeople                6.2.0-1           6.3.0-1                -0,05 MiB                  0,36 MiB
extra/kpty                   6.2.0-1           6.3.0-1                -0,01 MiB                  0,19 MiB
extra/kquickcharts           6.2.0-1           6.3.0-1                 0,01 MiB                  0,17 MiB
extra/krunner                6.2.0-1           6.3.0-1                -0,02 MiB                  0,40 MiB
extra/kservice               6.2.0-1           6.3.0-1                 0,02 MiB                  0,42 MiB
extra/kstatusnotifieritem    6.2.0-1           6.3.0-1                 0,01 MiB                  0,24 MiB
extra/ksvg                   6.2.0-1           6.3.0-1                 0,02 MiB                  0,32 MiB
extra/ktexteditor            6.2.0-1           6.3.0-1                -0,08 MiB                  3,46 MiB
extra/ktextwidgets           6.2.0-1           6.3.0-1                -0,19 MiB                  0,62 MiB
extra/kunitconversion        6.2.0-1           6.3.0-1                 0,02 MiB                  1,07 MiB
extra/kuserfeedback          6.2.0-1           6.3.0-1                 0,00 MiB                  0,52 MiB
extra/kwallet                6.2.1-1           6.3.0-1                 0,00 MiB                  0,61 MiB
extra/kwidgetsaddons         6.2.2-1           6.3.0-1                -0,02 MiB                  3,63 MiB
extra/kwindowsystem          6.2.0-1           6.3.0-1                 0,00 MiB                  0,78 MiB
extra/kxmlgui                6.2.0-1           6.3.0-1                -0,28 MiB                  1,31 MiB
extra/modemmanager-qt        6.2.0-1           6.3.0-1                 0,00 MiB                  0,57 MiB
extra/networkmanager-qt      6.2.0-1           6.3.0-1                -0,13 MiB                  1,58 MiB
extra/prison                 6.2.0-1           6.3.0-1                 0,05 MiB                  0,25 MiB
extra/purpose                6.2.0-1           6.3.0-1                 0,00 MiB                  0,36 MiB
extra/qqc2-desktop-style     6.2.0-1           6.3.0-1                 0,06 MiB                  0,42 MiB
extra/solid                  6.2.0-1           6.3.0-1                -0,05 MiB                  0,81 MiB
extra/sonnet                 6.2.0-1           6.3.0-1                -0,10 MiB                  0,57 MiB
extra/syndication            6.2.0-1           6.3.0-1                 0,04 MiB                  0,67 MiB
extra/syntax-highlighting    6.2.0-1           6.3.0-1                -0,01 MiB                  1,51 MiB
extra/threadweaver           6.2.0-1           6.3.0-1                 0,01 MiB                  0,45 MiB
endeavouros/eos-bash-shared  24.16.11-1        24.16.11-1              0,00 MiB
Taille totale du téléchargement :   53,09 MiB
Taille totale installée :          237,95 MiB
Taille de mise à jour nette :        0,20 MiB
:: Procéder à l’installation ? [O/n]
:: Récupération des paquets…
 ki18n-6.3.0-1-x86_64                 1936,1 KiB   196 KiB/s 00:10 [------------------------------------] 100%
 kwidgetsaddons-6.3.0-1-x86_64           3,6 MiB   343 KiB/s 00:11 [------------------------------------] 100%
 kio-6.3.0-1-x86_64                      5,3 MiB   476 KiB/s 00:11 [------------------------------------] 100%
 kconfig-6.3.0-1-x86_64               1358,6 KiB   443 KiB/s 00:03 [------------------------------------] 100%
 networkmanager-qt-6.3.0-1-x86_64     1617,6 KiB   339 KiB/s 00:05 [------------------------------------] 100%
 ktexteditor-6.3.0-1-x86_64              3,5 MiB   234 KiB/s 00:15 [------------------------------------] 100%
 syntax-highlighting-6.3.0-1-x86_64   1546,6 KiB   217 KiB/s 00:07 [------------------------------------] 100%
 kcoreaddons-6.3.0-1-x86_64           1227,0 KiB   293 KiB/s 00:04 [------------------------------------] 100%
 kxmlgui-6.3.0-1-x86_64               1344,1 KiB   313 KiB/s 00:04 [------------------------------------] 100%
 kirigami-6.3.0-1-x86_64              1168,7 KiB   252 KiB/s 00:05 [------------------------------------] 100%
 knewstuff-6.3.0-1-x86_64              940,5 KiB   442 KiB/s 00:02 [------------------------------------] 100%
 kunitconversion-6.3.0-1-x86_64       1094,8 KiB   297 KiB/s 00:04 [------------------------------------] 100%
 bluez-qt-6.3.0-1-x86_64               933,3 KiB   326 KiB/s 00:03 [------------------------------------] 100%
 kcontacts-1:6.3.0-1-x86_64            871,1 KiB   366 KiB/s 00:02 [------------------------------------] 100%
 solid-6.3.0-1-x86_64                  828,1 KiB   369 KiB/s 00:02 [------------------------------------] 100%
 syndication-6.3.0-1-x86_64            682,8 KiB   391 KiB/s 00:02 [------------------------------------] 100%
 kwindowsystem-6.3.0-1-x86_64          797,9 KiB   349 KiB/s 00:02 [------------------------------------] 100%
 attica-6.3.0-1-x86_64                 734,6 KiB   297 KiB/s 00:02 [------------------------------------] 100%
 kconfigwidgets-6.3.0-1-x86_64         666,5 KiB   428 KiB/s 00:02 [------------------------------------] 100%
 baloo-6.3.0-1-x86_64                  672,2 KiB   270 KiB/s 00:02 [------------------------------------] 100%
 ktextwidgets-6.3.0-1-x86_64           634,5 KiB   299 KiB/s 00:02 [------------------------------------] 100%
 kwallet-6.3.0-1-x86_64                629,0 KiB   323 KiB/s 00:02 [------------------------------------] 100%
 breeze-icons-6.3.0-1-x86_64             7,8 MiB   298 KiB/s 00:27 [------------------------------------] 100%
 sonnet-6.3.0-1-x86_64                 584,2 KiB   269 KiB/s 00:02 [------------------------------------] 100%
 kitemmodels-6.3.0-1-x86_64            518,0 KiB   329 KiB/s 00:02 [------------------------------------] 100%
 kuserfeedback-6.3.0-1-x86_64          533,0 KiB   277 KiB/s 00:02 [------------------------------------] 100%
 modemmanager-qt-6.3.0-1-x86_64        581,6 KiB   223 KiB/s 00:03 [------------------------------------] 100%
 kfilemetadata-6.3.0-1-x86_64          503,2 KiB   250 KiB/s 00:02 [------------------------------------] 100%
 kparts-6.3.0-1-x86_64                 476,6 KiB   347 KiB/s 00:01 [------------------------------------] 100%
 kiconthemes-6.3.0-1-x86_64            501,9 KiB   261 KiB/s 00:02 [------------------------------------] 100%
 kcompletion-6.3.0-1-x86_64            468,8 KiB   165 KiB/s 00:03 [------------------------------------] 100%
 threadweaver-6.3.0-1-x86_64           459,4 KiB   176 KiB/s 00:03 [------------------------------------] 100%
 kservice-6.3.0-1-x86_64               427,2 KiB   195 KiB/s 00:02 [------------------------------------] 100%
 qqc2-desktop-style-6.3.0-1-x86_64     433,8 KiB   118 KiB/s 00:04 [------------------------------------] 100%
 kcmutils-6.3.0-1-x86_64               428,7 KiB   146 KiB/s 00:03 [------------------------------------] 100%
 kholidays-1:6.3.0-1-x86_64            427,1 KiB   194 KiB/s 00:02 [------------------------------------] 100%
 krunner-6.3.0-1-x86_64                412,7 KiB   246 KiB/s 00:02 [------------------------------------] 100%
 purpose-6.3.0-1-x86_64                368,0 KiB   189 KiB/s 00:02 [------------------------------------] 100%
 karchive-6.3.0-1-x86_64               422,9 KiB   128 KiB/s 00:03 [------------------------------------] 100%
 kpeople-6.3.0-1-x86_64                369,2 KiB   136 KiB/s 00:03 [------------------------------------] 100%
 kguiaddons-6.3.0-1-x86_64             354,1 KiB   211 KiB/s 00:02 [------------------------------------] 100%
 kcodecs-6.3.0-1-x86_64                356,1 KiB   154 KiB/s 00:02 [------------------------------------] 100%
 kpackage-6.3.0-1-x86_64               330,8 KiB   196 KiB/s 00:02 [------------------------------------] 100%
 kbookmarks-6.3.0-1-x86_64             346,7 KiB   179 KiB/s 00:02 [------------------------------------] 100%
 ksvg-6.3.0-1-x86_64                   330,2 KiB   200 KiB/s 00:02 [------------------------------------] 100%
 kitemviews-6.3.0-1-x86_64             329,3 KiB   290 KiB/s 00:01 [------------------------------------] 100%
 knotifications-6.3.0-1-x86_64         293,5 KiB   260 KiB/s 00:01 [------------------------------------] 100%
 kdeclarative-6.3.0-1-x86_64           277,4 KiB   321 KiB/s 00:01 [------------------------------------] 100%
 kjobwidgets-6.3.0-1-x86_64            288,4 KiB   254 KiB/s 00:01 [------------------------------------] 100%
 kdnssd-6.3.0-1-x86_64                 277,5 KiB   261 KiB/s 00:01 [------------------------------------] 100%
 kauth-6.3.0-1-x86_64                  286,9 KiB   240 KiB/s 00:01 [------------------------------------] 100%
 prison-6.3.0-1-x86_64                 251,5 KiB   279 KiB/s 00:01 [------------------------------------] 100%
 kdesu-6.3.0-1-x86_64                  247,5 KiB   355 KiB/s 00:01 [------------------------------------] 100%
 kimageformats-6.3.0-1-x86_64          230,6 KiB   263 KiB/s 00:01 [------------------------------------] 100%
 kcolorscheme-6.3.0-1-x86_64           197,4 KiB   266 KiB/s 00:01 [------------------------------------] 100%
 kstatusnotifieritem-6.3.0-1-x86_64    243,8 KiB   261 KiB/s 00:01 [------------------------------------] 100%
 kglobalaccel-6.3.0-1-x86_64           210,7 KiB   267 KiB/s 00:01 [------------------------------------] 100%
 kdbusaddons-6.3.0-1-x86_64            196,1 KiB   353 KiB/s 00:01 [------------------------------------] 100%
 kquickcharts-6.3.0-1-x86_64           178,2 KiB   300 KiB/s 00:01 [------------------------------------] 100%
 knotifyconfig-6.3.0-1-x86_64          163,4 KiB   254 KiB/s 00:01 [------------------------------------] 100%
 kpty-6.3.0-1-x86_64                   191,3 KiB   233 KiB/s 00:01 [------------------------------------] 100%
 kidletime-6.3.0-1-x86_64              162,6 KiB   319 KiB/s 00:01 [------------------------------------] 100%
 fakeroot-1.35-1-x86_64                 75,9 KiB   299 KiB/s 00:00 [------------------------------------] 100%
 frameworkintegration-6.3.0-1-x86_64    71,2 KiB   318 KiB/s 00:00 [------------------------------------] 100%
 kcrash-6.3.0-1-x86_64                 132,2 KiB   183 KiB/s 00:01 [------------------------------------] 100%
 kded-6.3.0-1-x86_64                    56,8 KiB   213 KiB/s 00:00 [------------------------------------] 100%
 Total (66/66)                          53,1 MiB  1325 KiB/s 00:41 [------------------------------------] 100%
(67/67) vérification des clés dans le trousseau                    [------------------------------------] 100%
(67/67) vérification de l’intégrité des paquets                    [------------------------------------] 100%
(67/67) chargement des fichiers des paquets                        [------------------------------------] 100%
(67/67) analyse des conflits entre fichiers                        [------------------------------------] 100%
:: Traitement des changements du paquet…
( 1/67) réinstallation eos-bash-shared                             [------------------------------------] 100%
( 2/67) mise à jour de attica                                      [------------------------------------] 100%
( 3/67) mise à jour de kconfig                                     [------------------------------------] 100%
( 4/67) mise à jour de kcoreaddons                                 [------------------------------------] 100%
( 5/67) mise à jour de kcrash                                      [------------------------------------] 100%
( 6/67) mise à jour de kdbusaddons                                 [------------------------------------] 100%
( 7/67) mise à jour de karchive                                    [------------------------------------] 100%
( 8/67) mise à jour de kcodecs                                     [------------------------------------] 100%
( 9/67) mise à jour de ki18n                                       [------------------------------------] 100%
(10/67) mise à jour de kfilemetadata                               [------------------------------------] 100%
(11/67) mise à jour de kidletime                                   [------------------------------------] 100%
(12/67) mise à jour de kwindowsystem                               [------------------------------------] 100%
(13/67) mise à jour de kauth                                       [------------------------------------] 100%
(14/67) mise à jour de kguiaddons                                  [------------------------------------] 100%
(15/67) mise à jour de kcolorscheme                                [------------------------------------] 100%
(16/67) mise à jour de kwidgetsaddons                              [------------------------------------] 100%
(17/67) mise à jour de kconfigwidgets                              [------------------------------------] 100%
(18/67) mise à jour de kbookmarks                                  [------------------------------------] 100%
(19/67) mise à jour de kcompletion                                 [------------------------------------] 100%
(20/67) mise à jour de breeze-icons                                [------------------------------------] 100%
(21/67) mise à jour de kiconthemes                                 [------------------------------------] 100%
(22/67) mise à jour de kitemviews                                  [------------------------------------] 100%
(23/67) mise à jour de knotifications                              [------------------------------------] 100%
(24/67) mise à jour de kjobwidgets                                 [------------------------------------] 100%
(25/67) mise à jour de kservice                                    [------------------------------------] 100%
(26/67) mise à jour de kwallet                                     [------------------------------------] 100%
(27/67) mise à jour de solid                                       [------------------------------------] 100%
(28/67) mise à jour de kio                                         [------------------------------------] 100%
(29/67) mise à jour de baloo                                       [------------------------------------] 100%
(30/67) mise à jour de bluez-qt                                    [------------------------------------] 100%
(31/67) mise à jour de fakeroot                                    [------------------------------------] 100%
(32/67) mise à jour de kpackage                                    [------------------------------------] 100%
(33/67) mise à jour de syndication                                 [------------------------------------] 100%
(34/67) mise à jour de knewstuff                                   [------------------------------------] 100%
(35/67) mise à jour de frameworkintegration                        [------------------------------------] 100%
(36/67) mise à jour de kitemmodels                                 [------------------------------------] 100%
(37/67) mise à jour de kirigami                                    [------------------------------------] 100%
(38/67) mise à jour de kglobalaccel                                [------------------------------------] 100%
(39/67) mise à jour de kxmlgui                                     [------------------------------------] 100%
(40/67) mise à jour de kcmutils                                    [------------------------------------] 100%
(41/67) mise à jour de kcontacts                                   [------------------------------------] 100%
Nouvelles dépendances optionnelles pour kcontacts
    qt6-declarative: QML bindings [installé]
(42/67) mise à jour de kdeclarative                                [------------------------------------] 100%
(43/67) mise à jour de kded                                        [------------------------------------] 100%
(44/67) mise à jour de kpty                                        [------------------------------------] 100%
(45/67) mise à jour de kdesu                                       [------------------------------------] 100%
(46/67) mise à jour de kdnssd                                      [------------------------------------] 100%
(47/67) mise à jour de kholidays                                   [------------------------------------] 100%
(48/67) mise à jour de kimageformats                               [------------------------------------] 100%
(49/67) mise à jour de knotifyconfig                               [------------------------------------] 100%
(50/67) mise à jour de kparts                                      [------------------------------------] 100%
(51/67) mise à jour de kpeople                                     [------------------------------------] 100%
(52/67) mise à jour de kquickcharts                                [------------------------------------] 100%
(53/67) mise à jour de krunner                                     [------------------------------------] 100%
(54/67) mise à jour de kstatusnotifieritem                         [------------------------------------] 100%
(55/67) mise à jour de ksvg                                        [------------------------------------] 100%
(56/67) mise à jour de sonnet                                      [------------------------------------] 100%
(57/67) mise à jour de ktextwidgets                                [------------------------------------] 100%
(58/67) mise à jour de syntax-highlighting                         [------------------------------------] 100%
(59/67) mise à jour de ktexteditor                                 [------------------------------------] 100%
(60/67) mise à jour de kunitconversion                             [------------------------------------] 100%
(61/67) mise à jour de kuserfeedback                               [------------------------------------] 100%
(62/67) mise à jour de modemmanager-qt                             [------------------------------------] 100%
(63/67) mise à jour de networkmanager-qt                           [------------------------------------] 100%
(64/67) mise à jour de prison                                      [------------------------------------] 100%
(65/67) mise à jour de purpose                                     [------------------------------------] 100%
(66/67) mise à jour de qqc2-desktop-style                          [------------------------------------] 100%
(67/67) mise à jour de threadweaver                                [------------------------------------] 100%
:: Exécution des crochets (« hooks ») de post-transaction…
(1/8) Reloading system manager configuration...
(2/8) Reloading user manager configuration...
(3/8) Arming ConditionNeedsUpdate...
(4/8) Updating the MIME type database...
(5/8) Reloading system bus configuration...
(6/8) Updating icon theme caches...
(7/8) Checking which packages need to be rebuilt
(8/8) Updating the desktop file MIME type cache...
    /etc/passwd
    /etc/group
    /etc/shadow
sudo: unable to execute /tmp/tmp.ZDdW711iz0: Permission denied
same same :frowning:
