up with the latest ISO we also have a new enhanced more polished i3-setup:
@joekamprad I updated my i3wm-setup and now Default configuration suffers from completely transparent terminal. It also affects my terminal in XFCE.
Otherwise, looks great.
It’s the new defaults. Just adjust the slider in xfce4-terminal.
Perfect! Thanks.
is it ?
I3 has installed xfce4-terminal with a transparent background since I made that post and still does. It is set that way by the slider.
edit…just finished an install. This is what the terminal looks like on first boot.
could you show the xfce4-terminal config file? (both of you)
cat ~/.config/xfce4/terminal/terminalrc
[elloquin@elloquin-elloquin ~]$ cat ~/.config/xfce4/terminal/terminalrc
[Configuration]
BackgroundDarkness=0.700000
MiscSearchDialogOpacity=100
MiscShowUnsafePasteDialog=FALSE
BackgroundMode=TERMINAL_BACKGROUND_TRANSPARENT
MiscAlwaysShowTabs=FALSE
MiscBell=FALSE
MiscBellUrgent=FALSE
MiscBordersDefault=TRUE
MiscCursorBlinks=FALSE
MiscCursorShape=TERMINAL_CURSOR_SHAPE_BLOCK
MiscDefaultGeometry=100x30
MiscInheritGeometry=FALSE
MiscMenubarDefault=FALSE
MiscMouseAutohide=FALSE
MiscMouseWheelZoom=TRUE
MiscToolbarDefault=FALSE
MiscConfirmClose=TRUE
MiscCycleTabs=TRUE
MiscTabCloseButtons=TRUE
MiscTabCloseMiddleClick=TRUE
MiscTabPosition=GTK_POS_TOP
MiscHighlightUrls=TRUE
MiscMiddleClickOpensUri=FALSE
MiscCopyOnSelect=FALSE
MiscShowRelaunchDialog=TRUE
MiscRewrapOnResize=TRUE
MiscUseShiftArrowsToScroll=FALSE
MiscSlimTabs=TRUE
MiscNewTabAdjacent=FALSE
ColorForeground=#e3e3ea
ColorBackground=#08052b
ColorPalette=rgb(8,5,43);rgb(255,127,127);rgb(71,179,93);rgb(204,57,128);rgb(127,186,255);rgb(127,63,191);rgb(127,127,255);rgb(205,204,219);rgb(127,186,255);rgb(255,127,127);rgb(153,153,204);rgb(255,127,127);rgb(127,127,255);rgb(127,63,191);rgb(127,127,255);rgb(227,227,234)
ScrollingUnlimited=TRUE
TitleMode=TERMINAL_TITLE_REPLACE
ScrollingBar=TERMINAL_SCROLLBAR_NONE
TextBlinkMode=TERMINAL_TEXT_BLINK_MODE_FOCUSED
FontName=Source Code Pro 10
ColorCursorForeground=#FFFFFF
ColorCursor=#ff7f7f
ColorCursorUseDefault=FALSE
ColorBold=#7fbaff
ColorBoldIsBright=FALSE
TabActivityColor=#47B35D
I remember we had that issue a long time before… the .
(point) needs to be a ,
comma …
The issue was that it changed from comma to point on its own when it was copied over to system
