EndeavourOS stops working after last system update. Critical! Help!
Hello, 30 minutes ago I’ve updated my system. After that system stops working. What i mean. The system just stacked no meter how i start the system, event through tty session it`s stuck, user input not working, UI not responding. Now i booted through usb drive… Guys please help, its really critical, i need to finish my job))) Save me pls…)))
P.S. Before update I’ve installed drawio-desktop thorugh yay… Not sure that is mater… That app i’ve just removed but it’s not helps
Not understanding this? Do you mean the system is just stuck no matter how you start the system? It might be helpful if you can boot on the live ISO and at least post the hardware output.You need internet connected and post the url from the command.
inxi -Faz | eos-sendlog
Executed that command, but nothing happens
  Kernel: 6.7.1-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: tsc available: hpet,acpi_pm
    parameters: initrd=\arch\boot\intel-ucode.img
    initrd=\arch\boot\amd-ucode.img
    initrd=\arch\boot\x86_64\initramfs-linux.img archisobasedir=arch
    archisolabel=EOS_202401 cow_spacesize=10G copytoram=n
    module_blacklist=nvidia,nvidia_modeset,nvidia_uvm,nvidia_drm,pcspkr
    nouveau.modeset=1 i915.modeset=1 radeon.modeset=1 nvme_load=yes
  Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_x11 vt: 1
    dm: SDDM Distro: EndeavourOS base: Arch Linux
  Type: Laptop System: ASUSTeK product: ROG Flow X13 GV301QE_GV301QE v: 1.0
    serial: <superuser required>
  Mobo: ASUSTeK model: GV301QE v: 1.0 serial: <superuser required>
    UEFI: American Megatrends LLC. v: GV301QE.415 date: 04/14/2023
Battery:
  ID-1: BAT0 charge: 12.1 Wh (19.8%) condition: 61.2/60.2 Wh (101.7%)
    power: 0.9 W volts: 15.5 min: 15.5 model: ASUSTeK ASUS Battery type: Li-ion
    serial: N/A status: charging
  Device-1: hid-dc:2c:26:0a:e5:24-battery model: Keychron K2 serial: N/A
    charge: N/A status: discharging
  Info: model: AMD Ryzen 9 5900HS with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
    process: TSMC n7 (7nm) family: 0x19 (25) model-id: 0x50 (80) stepping: 0
    microcode: 0xA50000C
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 3274 high: 4487 min/max: 400/4680 scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 3834 2: 4467 3: 2554
    4: 3592 5: 4487 6: 2155 7: 2398 8: 4450 9: 4238 10: 400 11: 4090 12: 2780
    13: 4337 14: 400 15: 4240 16: 3970 bogomips: 105440
  Vulnerabilities:
  Type: gather_data_sampling status: Not affected
  Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
    prctl
    sanitization
    STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA GA107M [GeForce RTX 3050 Ti Mobile] vendor: ASUSTeK
    driver: nouveau v: kernel alternate: nvidia_drm,nvidia non-free: 545.xx+
    status: current (as of 2023-10; EOL~2026-12-xx) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 3 speed: 8 GT/s
    lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
    chip-ID: 10de:25a0 class-ID: 0302
  Device-2: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
    vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5 code: Vega
    process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
    link-max: gen: 4 speed: 16 GT/s ports: active: HDMI-A-1,eDP-1
    empty: DP-1,DP-2 bus-ID: 08:00.0 chip-ID: 1002:1638 class-ID: 0300
    temp: 67.0 C
  Device-3: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3 chip-ID: 13d3:56dd
    class-ID: 0e02 serial: <filter>
  Display: server: X.Org v: 21.1.11 compositor: kwin_x11 driver: X:
    loaded: amdgpu,modesetting unloaded: radeon alternate: fbdev,nouveau,nv,vesa
    dri: radeonsi,nouveau gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 4480x1440 s-dpi: 96 s-size: 1185x381mm (46.65x15.00")
    s-diag: 1245mm (49.01")
  Monitor-1: HDMI-A-1 mapped: HDMI-A-0 pos: primary,right
    model: Gigabyte M32QC serial: <filter> built: 2022 res: 2560x1440 hz: 60
    dpi: 93 gamma: 1.2 size: 697x392mm (27.44x15.43") diag: 800mm (31.5")
    ratio: 16:9 modes: max: 2560x1440 min: 720x400
  Monitor-2: eDP-1 mapped: eDP pos: left model: Sharp LQ134N1JW52
    built: 2020 res: 1920x1200 hz: 120 dpi: 169 gamma: 1.2
    size: 288x180mm (11.34x7.09") diag: 340mm (13.4") ratio: 16:10 modes:
    max: 1920x1200 min: 640x480
  API: EGL v: 1.5 hw: drv: nvidia nouveau drv: amd radeonsi platforms:
    device: 0 drv: radeonsi device: 1 drv: nouveau device: 2 drv: swrast gbm:
    drv: nouveau surfaceless: drv: radeonsi x11: drv: radeonsi
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.3 vendor: amd mesa v: 23.3.3-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (radeonsi
    renoir LLVM 16.0.6 DRM 3.56 6.7.1-arch1-1) device-ID: 1002:1638
    memory: 500 MiB unified: no
  Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s bus-ID: 08:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK
    driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x,
    snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
    snd_sof_amd_acp63 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s bus-ID: 08:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
    link-max: gen: 4 speed: 16 GT/s bus-ID: 08:00.6 chip-ID: 1022:15e3
    class-ID: 0403
  Device-4: JMTek LLC. USB PnP Audio Device
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-2.4.3:8 chip-ID: 0c76:161e class-ID: 0300
  API: ALSA v: k6.7.1-arch1-1 status: kernel-api
  Server-1: PipeWire v: 1.0.1 status: active with: 1: pipewire-pulse
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel modules: wl pcie:
    gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:2723
    class-ID: 0280
Bluetooth:
  Device-1: Intel AX200 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:5 chip-ID: 8087:0029
    class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2
    lmp-v: 11 status: discoverable: no pairing: no class-ID: 6c010c
  Local Storage: total: 968.71 GiB used: 204.74 GiB (21.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN530
    SDBPTPZ-1T00-1002 size: 953.87 GiB block-size: physical: 512 B
    logical: 512 B speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter>
    fw-rev: 21106000 temp: 43.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Innostor model: N/A size: 14.84 GiB
    block-size: physical: 512 B logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s
    lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 1.00 scheme: MBR
  SMART Message: Unknown USB bridge. Flash drive/Unsupported enclosure?
  ID-1: / raw-size: N/A size: 10 GiB used: 4.08 GiB (40.8%) fs: overlay
    source: ERR-102
  System Temperatures: cpu: 86.6 C mobo: N/A gpu: amdgpu temp: 74.0 C
  Fan Speeds (rpm): cpu: 5500
  Processes: 383 Uptime: 32m wakeups: 0 Memory: total: 32 GiB note: est.
  available: 30.76 GiB used: 12.57 GiB (40.9%) Init: systemd v: 255
  default: multi-user tool: systemctl Compilers: gcc: 13.2.1 Packages:
  pm: pacman pkgs: 978 libs: 220 tools: yay Shell: Bash v: 5.2.26
  running-in: konsole inxi: 3.3.31
edited by mod to add code tags.
Okay … can you put code tags around the output you posted?
Edit: You can use 3 back ticks ``` or 3 tilde ~~~ before and after what you posted or use the pre-formatted text button.
Sorry) I’m new one, what do you mean about code tags?
Did you mean, to wrap it in code?
I can edit it for you if you like.
Battery:
  Vulnerabilities:
    prctl
    sanitization
    temp: 67.0 C
    inactive: wayland
    class-ID: 0403
    class-ID: 0280
Bluetooth:
    class-ID: e001
    source: ERR-102
Sorry i already did it for you. Nice hardware!
Interesting it says that now swap data but i have a swap partition
I see swap in the image.
Edit: Anyway i see it’s a hybrid laptop with amdgpu and nvidia.
Yeah HW is nice, but i have problem with charging))) It not charging when i compiling smth or just gaming((( But that is not main problem now)
Do you know what happened when it updated?
Edit: Hardware output is fine. Looks like you didn’t install the nvidia drivers? It sjhows the open source nouveau for the nvidia gpu.
It’s just updated. After update i’ve reboot. After that i’ve booted normaly, started the session, it works fine couple of minutes and everything just have stucked… Dont noticed any errors during updating
Okay so it’s a little confusing. So it does boot to the desktop and logs in and then it freezes?
Yep, works fine 2-3 minutes and than it says me to go away… Can I disable nvidia card from usb drive system?
Not sure what you mean?
If problem in nvidia, mb i can just disable it and thats it… Dont know…
I don’t think that’s the issue. It could be the package you installed but you said you uninstalled it? Did it uninstall properly? Were you using yay to install and uninstall it?
