eos-breeze sddm file shows the logo and the eos background. Thats right
@manuel asked me to post the result to that command in another thread. This is the output…
❯ pacman -Q endeavouros-branding
error: package 'endeavouros-branding' was not found
That’s what confused me as i thought it would have the eos-logo in it on the login.
Im sure as a told in a post above the update didnt reached you yet. Dont know why. With the last update you have to replace as it shows in the other thread
You have confused me too
If you want you may take a look at @UncleSpellbinder’s github. He made a lot of logos.
Some are made, others are collected from the web.
Finally got it. @manuel suggested that I try installing, so I ran sudo pacman -Syu endeavouros-branding
and all seems to have gone well.
❯ sudo pacman -Syu endeavouros-branding
[sudo] password for wombat:
endeavouros is up to date
core is up to date
extra is up to date
multilib is up to date
:: Replace endeavouros-theming with endeavouros/endeavouros-branding? [Y/n]
:: Replace eos-plasma-sddm-config with endeavouros/eos-breeze-sddm? [Y/n]
resolving dependencies...
Package (4) Old Version New Version Net Change Download Size
endeavouros-theming 24.06.1.1-1 -4.32 MiB
endeavouros/eos-breeze-sddm 1.4-1 4.40 MiB 4.39 MiB
eos-plasma-sddm-config 22.03.1.2-1 0.00 MiB
endeavouros/endeavouros-branding 24.12.1.3-2 9.61 MiB 9.45 MiB
Total Download Size: 13.85 MiB
Total Installed Size: 14.01 MiB
Net Upgrade Size: 9.69 MiB
:: Proceed with installation? [Y/n]
:: Retrieving packages...
eos-breeze-sddm-1.4-1-any 4.4 MiB 16.8 MiB/s 00:00 [----------------------------------------] 100%
endeavouros-branding-24.12.1.3-2-any 9.5 MiB 31.6 MiB/s 00:00 [----------------------------------------] 100%
Total (2/2) 13.8 MiB 43.0 MiB/s 00:00 [----------------------------------------] 100%
(2/2) checking keys in keyring [----------------------------------------] 100%
(2/2) checking package integrity [----------------------------------------] 100%
(2/2) loading package files [----------------------------------------] 100%
(2/2) checking for file conflicts [----------------------------------------] 100%
:: Processing package changes...
(1/2) removing eos-plasma-sddm-config [----------------------------------------] 100%
(2/2) removing endeavouros-theming [----------------------------------------] 100%
(1/2) installing endeavouros-branding [----------------------------------------] 100%
(2/2) installing eos-breeze-sddm [----------------------------------------] 100%
To use this theme, add the following lines to /etc/sddm.conf
any dropin you may use under /etc/sddm.conf.d
or simply use plasma settings (sddm-kcm) to choose theme for sddm
[Theme]
Current=eos-breeze
(1/1) Arming ConditionNeedsUpdate...
Well done. I followed the other thread. I already noticed it
Is there a way to filter the AI slop from the wallpapers?
I keep deleting the “rocket” wallpaper but it keeps coming back when I update
That’s because it’s part of the package that is getting updated. Right?
