When you first installed EOS did you do a regular (not Nvidia) install and then install the drivers after?
You may be missing the nvidia-hook package from the EOS Repo, it is included when you do an Nvidia install of EOS or run nvidia-inst.
I’m encountering the same issue as OP.
Ran a system update via yay, rebooted to a blank screen. No systemd-boot menu.
Tried an EFI boot by selecting the systemd-bootx64.efi file directly, but the issue persisted.
Among the packages updated were linux linux-lts linux-firmware systemd systemd-libs and various nvidia packages. Though I don’t see how it could be an nvidia issue.
After chrooting, I tried sudo reinstall-kernels, reinstalling the kernels, and downgrading one of the kernels to the version I had before the update. Nothing worked.
My suspect is the systemd efi file, but I don’t know how to deal with it.
Disabled legacy boot from BIOS options and was able to boot successfully.
Still don’t know what the culprit package is.
Ok, great to know, thank you!
When booting from the install medium, I always selected the NVIDIA install for the latest cards. And the problem persists even after manually running nvidia-inst.
As I wrote earlier, I’m not even sure it’s an NVIDIA problem anymore, since everything runs fine after replacing systemd-boot with GRUB.
This is a systemdboot issue. Somthing is wrong with it as my system is back to normal with grub. It survived an update.
I had legacy bios turned off on my cmp the second time i got hit with this. So anyways back to grub and all is well it seams.
That is pretty unlikely I think. More likely it is something to do with initrd creation that was fixed in migrating to grub.
Not sure. This bug came up on a fresh install of eos using systemdboot as well. I went through the steps rebuilding with dracut. Rebuilding systemdboot. Booting to a blank screen no matter what.
Fresh install of eos with grub and it survied a kernelupdate. Ill leave it be for now.
