Bravissimo ENOS’ dev team!
Right click on terminal and change opacity, I learned something right there!
I use i3wm at work, love it!
@pebcak That a very good video + it show EOS in good light sad he got dmenu+rofi mix up
( small thing )
for sharing the video
I like i3 but I still want multiple virtual desktops
It’s been awhile since I’ve used i3, but I used to use a boat load on it. Is that something that doesn’t work anymore?
i never saw it with multiple desktops or figured out how to do it or i’d still be using it probably. mate is so easy. no need to spend days ricing it. Though i am truly not against doing that.
With window managers it’s up to you if you want it or not. If it’s not in your config file you can add it. I3 documentation is fantastic. I had 6 I think.
