I do have a Nvidia video card, but the “-” is not blinking.
Here is the output of inxi:
[root@EndeavourOS /]# inxi -Fza
12System:
12Kernel 6.9.6-arch1-1 12arch x86_64 12bits 64 12compiler gcc 12v 14.1.1 12clocksource tsc 12avail acpi_pm
12parameters initrd=\arch\boot\intel-ucode.img initrd=\arch\boot\amd-ucode.img
initrd=\arch\boot\x86_64\initramfs-linux.img archisobasedir=arch archisolabel=EOS_202406
cow_spacesize=10G copytoram=n
module_blacklist=nvidia,nvidia_modeset,nvidia_uvm,nvidia_drm,pcspkr nouveau.modeset=1
i915.modeset=1 radeon.modeset=1 nvme_load=yes
12Desktop KDE Plasma 12v ERR-101 12tk Qt 12v N/A 12wm kwin_x11 12dm startx 12Distro EndeavourOS
12base Arch Linux
12Machine:
12Type Laptop 12System HP 12product HP ZBook Studio 15.6 inch G8 Mobile Workstation PC 12v SBKPF
12serial <filter> 12Chassis 12type 10 12serial <filter>
12Mobo HP 12model 8873 12v KBC Version 53.39.00 12serial <filter> 12part-nu 30M95AV
12uuid 7058ff82-ff21-443e-8cf0-bb8aec5e87cd 12UEFI HP 12v T92 Ver. 01.15.00 12date 10/11/2023
12Battery:
12ID-1 BAT0 12charge 33.1 Wh (55.0%) 12condition 60.2/83.2 Wh (72.4%) 12volts 12.4 12min 11.6
12model Hewlett-Packard Primary 12type Li-ion 12serial <filter> 12status charging 12cycles 173
12CPU:
12Info 12model 11th Gen Intel Core i9-11950H 12socket U3E1 12bits 64 12type MT MCP 12arch Tiger Lake
12gen core 11 12level v4 12note check 12built 2020 12process Intel 10nm 12family 6 12model-id 0x8D (141)
12stepping 1 12microcode 0x50
12Topology 12cpus 1x 12cores 8 12tpc 2 12threads 16 12smt enabled 12cache 12L1 640 KiB
12desc d-8x48 KiB; i-8x32 KiB 12L2 10 MiB 12desc 8x1.2 MiB 12L3 24 MiB 12desc 1x24 MiB
12Speed (MHz) 12avg 819 12high 1006 12min/max 800/4900:5000 12base/boost 2574/5000 12scaling
12driver intel_pstate 12governor powersave 12volts 0.8 V 12ext-clock 100 MHz 12cores 121 800 122 800 123 800
124 800 125 800 126 1006 127 900 128 800 129 800 1210 800 1211 800 1212 800 1213 800 1214 800 1215 800 1216 800
12bogomips 83584
12Flags avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
12Vulnerabilities
12Type gather_data_sampling 12mitigation Microcode
12Type itlb_multihit 12status Not affected
12Type l1tf 12status Not affected
12Type mds 12status Not affected
12Type meltdown 12status Not affected
12Type mmio_stale_data 12status Not affected
12Type reg_file_data_sampling 12status Not affected
12Type retbleed 12status Not affected
12Type spec_rstack_overflow 12status Not affected
12Type spec_store_bypass 12mitigation Speculative Store Bypass disabled via prctl
12Type spectre_v1 12mitigation usercopy/swapgs barriers and __user pointer sanitization
12Type spectre_v2 12mitigation Enhanced / Automatic IBRS; IBPB: conditional; RSB filling;
PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
12Type srbds 12status Not affected
12Type tsx_async_abort 12status Not affected
12Graphics:
12Device-1 Intel TigerLake-H GT1 [UHD Graphics] 12vendor Hewlett-Packard 12driver i915 12v kernel
12arch Gen-12.1 12process Intel 10nm 12built 2020-21 12ports 12active eDP-1 12empty DP-1, DP-2, DP-3,
HDMI-A-1 12bus-ID 00:02.0 12chip-ID 8086:9a60 12class-ID 0300
12Device-2 NVIDIA TU117GLM [T1200 Laptop GPU] 12vendor Hewlett-Packard 12driver nouveau 12v kernel
12non-free 550.xx+ 12status current (as of 2024-06; EOL~2026-12-xx) 12arch Turing 12code TUxxx
12process TSMC 12nm FF 12built 2018-2022 12pcie 12gen 4 12speed 16 GT/s 12lanes 8 12link-max 12lanes 16 12ports
12active none 12empty DP-4,DP-5,HDMI-A-2 12bus-ID 01:00.0 12chip-ID 10de:1fbc 12class-ID 0300
12Device-3 Quanta HP HD Camera 12driver uvcvideo 12type USB 12rev 2.0 12speed 480 Mb/s 12lanes 1 12mode 2.0
12bus-ID 3-7:3 12chip-ID 0408:5441 12class-ID fe01 12serial <filter>
12Display 12server X.org 12v 1.21.1.13 12with Xwayland 12v 24.1.2 12compositor kwin_x11 12driver 12X
12loaded nvidia 12gpu i915 12display-ID :0
12Monitor-1 eDP-1 12model Samsung 0x4145 12built 2019 12res 3840x2160 12dpi 284 12gamma 1.2
12size 344x194mm (13.54x7.64") 12diag 395mm (15.5") 12ratio 16:9 12modes 3840x2160
12API EGL 12v 1.5 12hw 12drv intel iris 12drv nvidia nouveau 12platforms 12device 0 12drv iris 12device 1
12drv nouveau 12device 2 12drv swrast 12gbm 12drv iris 12surfaceless 12drv iris 12inactive wayland,x11
12API OpenGL 12v 4.6 12compat-v 4.3 12vendor mesa 12v 24.2.2-arch1.1 12note incomplete (EGL sourced)
12renderer Mesa Intel UHD Graphics (TGL GT1), NV167, llvmpipe (LLVM 18.1.8 256 bits)
12API Vulkan 12Message No Vulkan data available.
12Audio:
12Device-1 Intel Tiger Lake-H HD Audio 12vendor Hewlett-Packard 12driver sof-audio-pci-intel-tgl
12bus-ID 00:1f.3 12chip-ID 8086:43c8 12class-ID 0401
12Device-2 NVIDIA 12vendor Hewlett-Packard 12driver snd_hda_intel 12v kernel 12pcie 12gen 4 12speed 16 GT/s
12lanes 8 12link-max 12lanes 16 12bus-ID 01:00.1 12chip-ID 10de:10fa 12class-ID 0403
12API ALSA 12v k6.9.6-arch1-1 12status kernel-api 12tools alsactl,alsamixer,amixer
12Server-1 PipeWire 12v 1.2.3 12status n/a (root, process) 12with 121 pipewire-pulse 12status active
122 wireplumber 12status active 123 pipewire-alsa 12type plugin 124 pw-jack 12type plugin
12tools pactl,pw-cat,pw-cli,wpctl
12Network:
12Device-1 Intel Tiger Lake PCH CNVi WiFi 12driver iwlwifi 12v kernel 12bus-ID 00:14.3 12chip-ID 8086:43f0
12class-ID 0280
12IF wlan0 12state down 12mac <filter>
12Device-2 Realtek RTL8153 Gigabit Ethernet Adapter 12driver r8152 12type USB 12rev 3.0 12speed 5 Gb/s
12lanes 1 12mode 3.2 gen-1x1 12bus-ID 2-1.1:3 12chip-ID 0bda:8153 12class-ID 0000 12serial <filter>
12IF enp0s13f0u1u1 12state up 12speed 100 Mbps 12duplex full 12mac <filter>
12Info 12services NetworkManager, systemd-networkd, systemd-timesyncd, wpa_supplicant
12Bluetooth:
12Device-1 Intel AX201 Bluetooth 12driver btusb 12v 0.8 12type USB 12rev 2.0 12speed 12 Mb/s 12lanes 1 12mode 1.1
12bus-ID 3-14:6 12chip-ID 8087:0026 12class-ID e001
12Report btmgmt 12ID hci0 12rfk-id 0 12state up 12address <filter> 12bt-v 5.2 12lmp-v 11 12status
12discoverable no 12pairing no 12class-ID 6c010c
12Drives:
12Local Storage 12total 1.82 TiB 12used 628.46 GiB (33.7%)
12ID-1 /dev/nvme0n1 12maj-min 259:0 12vendor Samsung 12model SSD 990 PRO 2TB 12size 1.82 TiB 12block-size
12physical 512 B 12logical 512 B 12speed 63.2 Gb/s 12lanes 4 12tech SSD 12serial <filter> 12fw-rev 3B2QJXD7
12temp 32.9 C
12SMART yes 12health PASSED 12on 30d 14h 12cycles 262 12read-units 65,485,988 [33.5 TB]
12written-units 19,482,329 [9.97 TB]
12ID-2 /dev/sda 12maj-min 8:0 12model N/A 12size 3.75 GiB 12block-size 12physical 512 B 12logical 512 B
12type USB 12rev 2.0 12spd 480 Mb/s 12lanes 1 12mode 2.0 12tech N/A 12serial <filter> 12fw-rev 2.00
12SMART Message Unknown USB bridge. Flash drive/Unsupported enclosure?
12Partition:
12ID-1 / 12raw-size 975.47 GiB 12size 959.09 GiB (98.32%) 12used 627.93 GiB (65.5%) 12fs ext4
12block-size 4096 B 12dev /dev/nvme0n1p6 12maj-min 259:6
12ID-2 /boot 12raw-size 1000 MiB 12size 998 MiB (99.80%) 12used 540.1 MiB (54.1%) 12fs vfat
12block-size 512 B 12dev /dev/nvme0n1p5 12maj-min 259:5
12Swap:
12Alert No swap data was found.
12Sensors:
12System Temperatures 12cpu 39.0 C 12mobo N/A
12Fan Speeds (rpm) N/A
12Info:
12Memory 12total 16 GiB 12available 15.34 GiB 12used 2.72 GiB (17.7%) 12igpu 64 MiB
12Processes 325 12Power 12uptime 7m 12states freeze,mem,disk 12suspend s2idle 12avail deep 12wakeups 0
12hibernate platform 12avail shutdown, reboot, suspend, test_resume 12image 6.08 GiB
12services org_kde_powerdevil, power-profiles-daemon, upowerd 12Init systemd 12v 256
12default graphical 12tool systemctl
12Packages 1447 12pm pacman 12pkgs 1431 12libs 364 12tools yay 12pm flatpak 12pkgs 16 12Compilers 12clang 18.1.8
12gcc 14.2.1 12Client systemd 12inxi 3.3.35
Here is the journalctl:
[root@EndeavourOS /]# journalctl -b -1 -p4
Sep 17 22:58:53 landry-PC kernel: x86/mktme: No known encryption algorithm is supported: 0x0
Sep 17 22:58:53 landry-PC kernel: pnp 00:05: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
Sep 17 22:58:53 landry-PC kernel: hpet_acpi_add: no address or irqs in _CRS
Sep 17 22:58:53 landry-PC kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Sep 17 22:58:54 landry-PC kernel: wmi_bus wmi_bus-PNP0C14:02: [Firmware Bug]: WQZZ data block query control method not found
Sep 17 22:58:54 landry-PC kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
Sep 17 22:58:54 landry-PC kernel: platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
Sep 17 22:58:54 landry-PC kernel: nvidia: loading out-of-tree module taints kernel.
Sep 17 22:58:54 landry-PC kernel: nvidia: module license 'NVIDIA' taints kernel.
Sep 17 22:58:54 landry-PC kernel: Disabling lock debugging due to kernel taint
Sep 17 22:58:54 landry-PC kernel: nvidia: module license taints kernel.
Sep 17 22:58:54 landry-PC kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 560.35.03 Fri Aug 16 21:39:15 UTC 2024
Sep 17 22:58:54 landry-PC kernel: i2c_hid_acpi i2c-ELAN2513:00: i2c_hid_get_input: IRQ triggered but there's no data
Sep 17 22:58:54 landry-PC kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
Sep 17 22:58:54 landry-PC kernel: ------------[ cut here ]------------
Sep 17 22:58:54 landry-PC kernel: Unpatched return thunk in use. This should not happen!
Sep 17 22:58:54 landry-PC kernel: WARNING: CPU: 11 PID: 325 at arch/x86/kernel/cpu/bugs.c:3023 __warn_thunk+0x2a/0x40
Sep 17 22:58:54 landry-PC kernel: Modules linked in: crc32c_intel wl(POE+) nvidia_drm(POE+) polyval_clmulni polyval_generic nvidia_modeset(POE) gf128mul ghash_clmulni_intel hid_multitouch(+) sha512_ssse3 serio_raw hid_generic sha256_ssse3 rtsx_pci_sdmmc atkbd i2c_algo_bit n>
Sep 17 22:58:54 landry-PC kernel: CPU: 11 PID: 325 Comm: (udev-worker) Tainted: P OE 6.10.10-arch1-1 #1 e28ee6293423e91d57555c4cc06eb839714254b7
Sep 17 22:58:54 landry-PC kernel: Hardware name: HP HP ZBook Studio 15.6 inch G8 Mobile Workstation PC/8873, BIOS T92 Ver. 01.15.00 10/11/2023
Sep 17 22:58:54 landry-PC kernel: RIP: 0010:__warn_thunk+0x2a/0x40
Sep 17 22:58:54 landry-PC kernel: Code: 66 0f 1f 00 0f 1f 44 00 00 80 3d 70 c4 17 02 00 74 05 c3 cc cc cc cc 48 c7 c7 80 24 27 af c6 05 5b c4 17 02 01 e8 36 2a 06 00 <0f> 0b c3 cc cc cc cc 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00
Sep 17 22:58:54 landry-PC kernel: RSP: 0018:ffffbcc78761ba70 EFLAGS: 00010286
Sep 17 22:58:54 landry-PC kernel: RAX: 0000000000000000 RBX: 0000000000000000 RCX: 0000000000000027
Sep 17 22:58:54 landry-PC kernel: RDX: ffff91b25f7a19c8 RSI: 0000000000000001 RDI: ffff91b25f7a19c0
Sep 17 22:58:54 landry-PC kernel: RBP: ffffbcc78761bac0 R08: 0000000000000000 R09: ffffbcc78761b8f0
Sep 17 22:58:54 landry-PC kernel: R10: ffffffffafab21e8 R11: 0000000000000003 R12: ffffffffc6165ac1
Sep 17 22:58:54 landry-PC kernel: R13: ffffbcc78761bb08 R14: ffff91aed6304600 R15: ffff91aece40dbd8
Sep 17 22:58:54 landry-PC kernel: FS: 00007789caad4880(0000) GS:ffff91b25f780000(0000) knlGS:0000000000000000
Sep 17 22:58:54 landry-PC kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Sep 17 22:58:54 landry-PC kernel: CR2: 00007b3ed0cf2008 CR3: 0000000122d70004 CR4: 0000000000f70ef0
Sep 17 22:58:54 landry-PC kernel: PKRU: 55555554
Sep 17 22:58:54 landry-PC kernel: Call Trace:
Sep 17 22:58:54 landry-PC kernel: <TASK>
Sep 17 22:58:54 landry-PC kernel: ? __warn_thunk+0x2a/0x40
Sep 17 22:58:54 landry-PC kernel: ? __warn.cold+0x8e/0xe8
Sep 17 22:58:54 landry-PC kernel: ? report_bug+0xff/0x140
Sep 17 22:58:54 landry-PC kernel: ? handle_bug+0x3c/0x80
Sep 17 22:58:54 landry-PC kernel: ? exc_invalid_op+0x17/0x70
Sep 17 22:58:54 landry-PC kernel: ? asm_exc_invalid_op+0x1a/0x20
Sep 17 22:58:54 landry-PC kernel: warn_thunk_thunk+0x1a/0x30
Sep 17 22:58:54 landry-PC kernel: getvar+0x20/0x70 [wl d63010542f7253db7af14c99edc60d9e479360b9]
Sep 17 22:58:54 landry-PC kernel: ? __UNIQUE_ID_vermagic434+0x433838e064b3/0x433838e064b3 [wl d63010542f7253db7af14c99edc60d9e479360b9]
Sep 17 22:58:54 landry-PC kernel: wl_module_init+0x17/0xa0 [wl d63010542f7253db7af14c99edc60d9e479360b9]
Sep 17 22:58:54 landry-PC kernel: ? do_one_initcall+0x58/0x310
Sep 17 22:58:54 landry-PC kernel: ? do_init_module+0x60/0x220
Sep 17 22:58:54 landry-PC kernel: ? init_module_from_file+0x89/0xe0
Sep 17 22:58:54 landry-PC kernel: ? idempotent_init_module+0x121/0x320
Sep 17 22:58:54 landry-PC kernel: ? __x64_sys_finit_module+0x5e/0xb0
Sep 17 22:58:54 landry-PC kernel: ? do_syscall_64+0x82/0x190
Sep 17 22:58:54 landry-PC kernel: ? vfs_read+0x159/0x370
Sep 17 22:58:54 landry-PC kernel: ? __seccomp_filter+0x303/0x520
Sep 17 22:58:54 landry-PC kernel: ? syscall_exit_to_user_mode+0x72/0x200
Sep 17 22:58:54 landry-PC kernel: ? do_syscall_64+0x8e/0x190
Sep 17 22:58:54 landry-PC kernel: ? clear_bhb_loop+0x25/0x80
Sep 17 22:58:54 landry-PC kernel: ? entry_SYSCALL_64_after_hwframe+0x76/0x7e
Sep 17 22:58:54 landry-PC kernel: </TASK>
Sep 17 22:58:54 landry-PC kernel: ---[ end trace 0000000000000000 ]---
Sep 17 22:58:54 landry-PC kernel: ACPI Warning: \_SB.NPCF._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20240322/nsarguments-61)
Sep 17 22:58:54 landry-PC kernel: ACPI Warning: \_SB.PC00.PEG1.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20240322/nsarguments-61)
Sep 17 22:58:56 landry-PC kernel: sd 0:0:0:0: [sda] No Caching mode page found
Sep 17 22:58:56 landry-PC kernel: sd 0:0:0:0: [sda] Assuming drive cache: write through
Sep 17 22:58:58 landry-PC kernel: hp_wmi: query 0x4 returned error 0x5
Sep 17 22:58:58 landry-PC kernel: resource: resource sanity check: requesting [mem 0x00000000fedc0000-0x00000000fedcdfff], which spans more than pnp 00:05 [mem 0xfedc0000-0xfedc7fff]
Sep 17 22:58:58 landry-PC kernel: caller __uncore_imc_init_box+0xd7/0x120 [intel_uncore] mapping multiple BARs
Sep 17 22:58:59 landry-PC kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: Parent card not yet available, widget card binding deferred
Sep 17 22:58:59 landry-PC bootctl[702]: ! Mount point '/efi' which backs the random seed file is world accessible, which is a security hole! !
Sep 17 22:58:59 landry-PC bootctl[702]: ! Random seed file '/efi/loader/random-seed' is world accessible, which is a security hole! !
Sep 17 22:58:59 landry-PC bluetoothd[717]: src/plugin.c:init_plugin() System does not support bap plugin
Sep 17 22:58:59 landry-PC bluetoothd[717]: src/plugin.c:init_plugin() System does not support bass plugin
Sep 17 22:58:59 landry-PC bluetoothd[717]: src/plugin.c:init_plugin() System does not support mcp plugin
Sep 17 22:58:59 landry-PC bluetoothd[717]: src/plugin.c:init_plugin() System does not support vcp plugin
Sep 17 22:58:59 landry-PC bluetoothd[717]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
Sep 17 22:58:59 landry-PC bluetoothd[717]: src/plugin.c:init_plugin() System does not support micp plugin
Sep 17 22:58:59 landry-PC bluetoothd[717]: src/plugin.c:init_plugin() System does not support ccp plugin
Sep 17 22:58:59 landry-PC bluetoothd[717]: src/plugin.c:init_plugin() System does not support csip plugin
Sep 17 22:58:59 landry-PC bluetoothd[717]: src/plugin.c:init_plugin() System does not support asha plugin
Sep 17 22:58:59 landry-PC boltd[718]: [b099bf7c-773a-domain0 ] udev: failed to determine if uid is stable: unknown NHI PCI id '0x9a1f'
Sep 17 22:58:59 landry-PC kernel: skl_hda_dsp_generic skl_hda_dsp_generic: hda_dsp_hdmi_build_controls: no PCM in topology for HDMI converter 3
Sep 17 22:59:00 landry-PC kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
Sep 17 22:59:00 landry-PC kernel: Bluetooth: hci0: HCI LE Coded PHY feature bit is set, but its usage is not supported.
Sep 17 22:59:00 landry-PC bluetoothd[717]: src/device.c:device_set_wake_support() Unable to set wake_support without RPA resolution
Sep 17 22:59:01 landry-PC dbus-broker-launch[713]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
Sep 17 22:59:02 landry-PC dbus-broker-launch[713]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Sep 17 22:59:03 landry-PC dbus-broker-launch[903]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Sep 17 22:59:03 landry-PC dbus-broker-launch[903]: Ignoring duplicate name 'org.freedesktop.FileManager1' in service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service'
Sep 17 22:59:03 landry-PC dbus-broker-launch[903]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Sep 17 22:59:03 landry-PC dbus-broker-launch[903]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Sep 17 22:59:03 landry-PC firewalld[720]: ERROR: NAME_CONFLICT: new_policy_object(): 'docker-forwarding'
Sep 17 22:59:03 landry-PC firewalld[720]: WARNING: COMMAND_FAILED: '/usr/bin/iptables -w10 -t nat -D PREROUTING -m addrtype --dst-type LOCAL -j DOCKER' failed: iptables v1.8.10 (nf_tables): Chain 'DOCKER' does not exist
Try `iptables -h' or 'iptables --help' for more information.
Sep 17 22:59:03 landry-PC firewalld[720]: WARNING: COMMAND_FAILED: '/usr/bin/iptables -w10 -t nat -D OUTPUT -m addrtype --dst-type LOCAL ! --dst 127.0.0.0/8 -j DOCKER' failed: iptables v1.8.10 (nf_tables): Chain 'DOCKER' does not exist
Sep 17 22:59:03 landry-PC firewalld[720]: WARNING: COMMAND_FAILED: '/usr/bin/iptables -w10 -t nat -D OUTPUT -m addrtype --dst-type LOCAL -j DOCKER' failed: iptables v1.8.10 (nf_tables): Chain 'DOCKER' does not exist
Sep 17 22:59:03 landry-PC firewalld[720]: WARNING: COMMAND_FAILED: '/usr/bin/iptables -w10 -t nat -D PREROUTING' failed: iptables: Bad rule (does a matching rule exist in that chain?).
Sep 17 22:59:03 landry-PC firewalld[720]: WARNING: COMMAND_FAILED: '/usr/bin/iptables -w10 -t nat -D OUTPUT' failed: iptables: Bad rule (does a matching rule exist in that chain?).
Sep 17 22:59:03 landry-PC firewalld[720]: WARNING: COMMAND_FAILED: '/usr/bin/iptables -w10 -t nat -F DOCKER' failed: iptables: No chain/target/match by that name.
Sep 17 22:59:03 landry-PC firewalld[720]: WARNING: COMMAND_FAILED: '/usr/bin/iptables -w10 -t nat -X DOCKER' failed: iptables: No chain/target/match by that name.
Sep 17 22:59:03 landry-PC firewalld[720]: WARNING: COMMAND_FAILED: '/usr/bin/iptables -w10 -t filter -F DOCKER' failed: iptables: No chain/target/match by that name.
Sep 17 22:59:03 landry-PC firewalld[720]: WARNING: COMMAND_FAILED: '/usr/bin/iptables -w10 -t filter -X DOCKER' failed: iptables: No chain/target/match by that name.
Sep 17 22:59:03 landry-PC firewalld[720]: WARNING: COMMAND_FAILED: '/usr/bin/iptables -w10 -t filter -F DOCKER-ISOLATION-STAGE-1' failed: iptables: No chain/target/match by that name.
Sep 17 22:59:03 landry-PC firewalld[720]: WARNING: COMMAND_FAILED: '/usr/bin/iptables -w10 -t filter -X DOCKER-ISOLATION-STAGE-1' failed: iptables: No chain/target/match by that name.
Sep 17 22:59:03 landry-PC firewalld[720]: WARNING: COMMAND_FAILED: '/usr/bin/iptables -w10 -t filter -F DOCKER-ISOLATION-STAGE-2' failed: iptables: No chain/target/match by that name.
Sep 17 22:59:03 landry-PC firewalld[720]: WARNING: COMMAND_FAILED: '/usr/bin/iptables -w10 -t filter -X DOCKER-ISOLATION-STAGE-2' failed: iptables: No chain/target/match by that name.
Sep 17 22:59:03 landry-PC firewalld[720]: WARNING: COMMAND_FAILED: '/usr/bin/iptables -w10 -t filter -F DOCKER-ISOLATION' failed: iptables: No chain/target/match by that name.
Sep 17 22:59:03 landry-PC firewalld[720]: WARNING: COMMAND_FAILED: '/usr/bin/iptables -w10 -t filter -X DOCKER-ISOLATION' failed: iptables: No chain/target/match by that name.
Sep 17 22:59:03 landry-PC firewalld[720]: WARNING: COMMAND_FAILED: '/usr/bin/ip6tables -w10 -t nat -D PREROUTING -m addrtype --dst-type LOCAL -j DOCKER' failed: ip6tables v1.8.10 (nf_tables): Chain 'DOCKER' does not exist
Try `ip6tables -h' or 'ip6tables --help' for more information.
Sep 17 22:59:03 landry-PC firewalld[720]: WARNING: COMMAND_FAILED: '/usr/bin/ip6tables -w10 -t nat -D OUTPUT -m addrtype --dst-type LOCAL ! --dst ::1/128 -j DOCKER' failed: ip6tables v1.8.10 (nf_tables): Chain 'DOCKER' does not exist
Sep 17 22:59:03 landry-PC firewalld[720]: WARNING: COMMAND_FAILED: '/usr/bin/ip6tables -w10 -t nat -D OUTPUT -m addrtype --dst-type LOCAL -j DOCKER' failed: ip6tables v1.8.10 (nf_tables): Chain 'DOCKER' does not exist
Sep 17 22:59:03 landry-PC firewalld[720]: WARNING: COMMAND_FAILED: '/usr/bin/ip6tables -w10 -t nat -D PREROUTING' failed: ip6tables: Bad rule (does a matching rule exist in that chain?).
Sep 17 22:59:03 landry-PC firewalld[720]: WARNING: COMMAND_FAILED: '/usr/bin/ip6tables -w10 -t nat -D OUTPUT' failed: ip6tables: Bad rule (does a matching rule exist in that chain?).
Sep 17 22:59:03 landry-PC firewalld[720]: WARNING: COMMAND_FAILED: '/usr/bin/ip6tables -w10 -t nat -F DOCKER' failed: ip6tables: No chain/target/match by that name.
Sep 17 22:59:03 landry-PC firewalld[720]: WARNING: COMMAND_FAILED: '/usr/bin/ip6tables -w10 -t nat -X DOCKER' failed: ip6tables: No chain/target/match by that name.
Sep 17 22:59:03 landry-PC firewalld[720]: WARNING: COMMAND_FAILED: '/usr/bin/ip6tables -w10 -t filter -F DOCKER' failed: ip6tables: No chain/target/match by that name.
Sep 17 22:59:03 landry-PC firewalld[720]: WARNING: COMMAND_FAILED: '/usr/bin/ip6tables -w10 -t filter -X DOCKER' failed: ip6tables: No chain/target/match by that name.
Sep 17 22:59:03 landry-PC firewalld[720]: WARNING: COMMAND_FAILED: '/usr/bin/ip6tables -w10 -t filter -F DOCKER-ISOLATION-STAGE-1' failed: ip6tables: No chain/target/match by that name.
Sep 17 22:59:03 landry-PC firewalld[720]: WARNING: COMMAND_FAILED: '/usr/bin/ip6tables -w10 -t filter -X DOCKER-ISOLATION-STAGE-1' failed: ip6tables: No chain/target/match by that name.
Sep 17 22:59:03 landry-PC firewalld[720]: WARNING: COMMAND_FAILED: '/usr/bin/ip6tables -w10 -t filter -F DOCKER-ISOLATION-STAGE-2' failed: ip6tables: No chain/target/match by that name.
Sep 17 22:59:03 landry-PC firewalld[720]: WARNING: COMMAND_FAILED: '/usr/bin/ip6tables -w10 -t filter -X DOCKER-ISOLATION-STAGE-2' failed: ip6tables: No chain/target/match by that name.
Sep 17 22:59:03 landry-PC firewalld[720]: WARNING: COMMAND_FAILED: '/usr/bin/ip6tables -w10 -t filter -F DOCKER-ISOLATION' failed: ip6tables: No chain/target/match by that name.
Sep 17 22:59:03 landry-PC firewalld[720]: WARNING: COMMAND_FAILED: '/usr/bin/ip6tables -w10 -t filter -X DOCKER-ISOLATION' failed: ip6tables: No chain/target/match by that name.
Sep 17 22:59:22 landry-PC NetworkManager[760]: <warn> [1726639162.9183] device (wlan0): no secrets: No agents were available for this request.
Sep 17 22:59:22 landry-PC NetworkManager[760]: <warn> [1726639162.9187] device (wlan0): Activation: failed for connection 'eduroam'
Sep 17 23:14:51 landry-PC sddm-helper[883]: Signal received: SIGTERM
Sep 17 23:14:51 landry-PC sddm-greeter-qt6[899]: Signal received: SIGTERM
Sep 17 23:14:51 landry-PC sddm[848]: Error from greeter session: "Process crashed"
Sep 17 23:14:51 landry-PC sddm[848]: Auth: sddm-helper (--socket /tmp/sddm-auth-85db30a9-1384-4a39-bffa-aeae708ac900 --id 2 --start /usr/bin/sddm-greeter-qt6 --socket /tmp/sddm-:0-GqIqyy --theme /usr/share/sddm/themes/breeze --user sddm --greeter) crashed (exit code 1)
Sep 17 23:14:51 landry-PC sddm[848]: Auth: sddm-helper exited with 1
Sep 17 23:14:51 landry-PC sddm[848]: Signal received: SIGTERM
Sep 17 23:14:52 landry-PC dbus-broker-launch[713]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
Also when I do dmesg, I have some weird messages saying modules are blacklisted:
[root@EndeavourOS /]# dmesg
[ 0.000000] Linux version 6.9.6-arch1-1 (linux@archlinux) (gcc (GCC) 14.1.1 20240522, GNU ld (GNU Binutils) 2.42.0) #1 SMP PREEMPT_DYNAMIC Fri, 21 Jun 2024 19:49:19 +0000
[ 0.000000] Command line: initrd=\arch\boot\intel-ucode.img initrd=\arch\boot\amd-ucode.img initrd=\arch\boot\x86_64\initramfs-linux.img archisobasedir=arch archisolabel=EOS_202406 cow_spacesize=10G copytoram=n module_blacklist=nvidia,nvidia_modeset,nvidia_uvm,nvidia_drm,pcspkr nouveau.modeset=1 i915.modeset=1 radeon.modeset=1 nvme_load=yes
[ 0.000000] x86/tme: enabled by BIOS
[ 0.000000] x86/mktme: No known encryption algorithm is supported: 0x0
[ 0.000000] x86/mktme: disabled by BIOS
[ 0.000000] x86/split lock detection: #AC: crashing the kernel on kernel split_locks and warning on user-space split_locks
[ 10.973250] Module pcspkr is blacklisted
[ 12.514068] wl: loading out-of-tree module taints kernel.
[ 12.514073] wl: module license 'MIXED/Proprietary' taints kernel.
[ 12.514074] Disabling lock debugging due to kernel taint
[ 12.514075] wl: module verification failed: signature and/or required key missing - tainting kernel
[ 12.514075] wl: module license taints kernel.
[ 12.518194] ------------[ cut here ]------------
[ 12.518195] Unpatched return thunk in use. This should not happen!
[ 12.518197] WARNING: CPU: 2 PID: 538 at arch/x86/kernel/cpu/bugs.c:3023 __warn_thunk+0x2a/0x40
[ 12.518201] Modules linked in: wl(POE+) iwlwifi hid_multitouch snd_hda_codec_hdmi processor_thermal_device_pci_legacy sha1_ssse3 nouveau(+) intel_rapl_msr processor_thermal_device processor_thermal_wt_hint processor_thermal_rfim processor_thermal_rapl intel_rapl_common processor_thermal_wt_req processor_thermal_power_floor processor_thermal_mbox snd_hda_intel intel_soc_dts_iosf mei_pxp hid_generic hp_wmi ee1004 spi_nor mei_hdcp btusb snd_intel_dspcfg snd_intel_sdw_acpi snd_hda_codec mxm_wmi ucsi_acpi snd_hda_core rapl snd_hwdep snd_pcm snd_timer snd soundcore btrtl btintel btbcm btmtk bluetooth typec_ucsi typec ecdh_generic wmi_bmof crc16 platform_profile roles mtd intel_cstate intel_lpss_pci intel_uncore cfg80211 i2c_i801 rfkill i2c_hid_acpi i2c_hid mei_me intel_lpss idma64 intel_pmc_core int3403_thermal mei pmt_telemetry pmt_class i2c_smbus int340x_thermal_zone int3400_thermal intel_hid acpi_thermal_rel intel_vsec mac_hid sparse_keymap pinctrl_tigerlake wireless_hotkey acpi_pad pkcs8_key_parser i2c_dev crypto_user
[ 12.518228] dm_mod nfnetlink ip_tables x_tables overlay squashfs loop isofs cdrom r8153_ecm cdc_ether usbnet xe drm_gpuvm drm_exec gpu_sched drm_suballoc_helper r8152 drm_ttm_helper mii libphy uas usb_storage i915 crc32_pclmul crc32c_intel sha512_ssse3 drm_buddy serio_raw i2c_algo_bit rtsx_pci_sdmmc sha256_ssse3 atkbd aesni_intel nvme ttm libps2 mmc_core vivaldi_fmap crypto_simd drm_display_helper nvme_core thunderbolt cryptd xhci_pci spi_intel_pci cec rtsx_pci nvme_auth spi_intel xhci_pci_renesas intel_gtt i8042 video serio wmi vmd
[ 12.518247] CPU: 2 PID: 538 Comm: (udev-worker) Tainted: P OE 6.9.6-arch1-1 #1 8d3e363979c9a1730a7b5efa0421fcd4efd8406b
[ 12.518249] Hardware name: HP HP ZBook Studio 15.6 inch G8 Mobile Workstation PC/8873, BIOS T92 Ver. 01.15.00 10/11/2023
[ 12.518250] RIP: 0010:__warn_thunk+0x2a/0x40
[ 12.518252] Code: 66 0f 1f 00 0f 1f 44 00 00 80 3d f0 a9 17 02 00 74 05 c3 cc cc cc cc 48 c7 c7 28 f6 e4 88 c6 05 db a9 17 02 01 e8 a6 16 06 00 <0f> 0b c3 cc cc cc cc 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00
[ 12.518253] RSP: 0018:ffffa95a026b3958 EFLAGS: 00010282
[ 12.518255] RAX: 0000000000000000 RBX: 0000000000000000 RCX: 0000000000000027
[ 12.518256] RDX: ffff97835f3219c8 RSI: 0000000000000001 RDI: ffff97835f3219c0
[ 12.518256] RBP: ffffa95a026b39a8 R08: 0000000000000000 R09: ffffa95a026b37d8
[ 12.518257] R10: ffffffff896b21a8 R11: 0000000000000003 R12: ffffffffc2034ac1
[ 12.518258] R13: ffffa95a026b39f0 R14: ffff977fd9e21f00 R15: ffff977fd80fd298
[ 12.518258] FS: 000074045014b880(0000) GS:ffff97835f300000(0000) knlGS:0000000000000000
[ 12.518259] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 12.518260] CR2: 000071abfe4e75b0 CR3: 000000011118a001 CR4: 0000000000f70ef0
[ 12.518261] PKRU: 55555554
[ 12.518261] Call Trace:
[ 12.518263] <TASK>
[ 12.518264] ? __warn_thunk+0x2a/0x40
[ 12.518266] ? __warn.cold+0x8e/0xe8
[ 12.518267] ? __warn_thunk+0x2a/0x40
[ 12.518272] ? report_bug+0xff/0x140
[ 12.518274] ? console_unlock+0x84/0x130
[ 12.518276] ? handle_bug+0x3c/0x80
[ 12.518277] ? exc_invalid_op+0x17/0x70
[ 12.518279] ? asm_exc_invalid_op+0x1a/0x20
[ 12.518281] ? __warn_thunk+0x2a/0x40
[ 12.518283] ? __warn_thunk+0x2a/0x40
[ 12.518285] warn_thunk_thunk+0x1a/0x30
[ 12.518287] getvar+0x20/0x70 [wl 119b9e6acf63a937ae63c9991233f62e1aefcaaa]
[ 12.518306] ? __UNIQUE_ID_vermagic434+0x56a5bd925573/0x56a5bd925573 [wl 119b9e6acf63a937ae63c9991233f62e1aefcaaa]
[ 12.518321] wl_module_init+0x17/0xa0 [wl 119b9e6acf63a937ae63c9991233f62e1aefcaaa]
[ 12.518336] ? do_one_initcall+0x58/0x310
[ 12.518338] ? do_init_module+0x60/0x220
[ 12.518340] ? init_module_from_file+0x89/0xe0
[ 12.518342] ? idempotent_init_module+0x121/0x2b0
[ 12.518343] ? __x64_sys_finit_module+0x5e/0xb0
[ 12.518344] ? do_syscall_64+0x83/0x190
[ 12.518346] ? switch_fpu_return+0x4e/0xd0
[ 12.518348] ? syscall_exit_to_user_mode+0x75/0x210
[ 12.518349] ? do_syscall_64+0x8f/0x190
[ 12.518351] ? path_openat+0xa1a/0x1110
[ 12.518353] ? do_sys_openat2+0x9c/0xe0
[ 12.518355] ? do_filp_open+0xc4/0x170
[ 12.518358] ? __slab_free+0xdf/0x2f0
[ 12.518359] ? __seccomp_filter+0x306/0x520
[ 12.518362] ? syscall_exit_to_user_mode_prepare+0x149/0x170
[ 12.518363] ? syscall_exit_to_user_mode+0x75/0x210
[ 12.518364] ? do_syscall_64+0x8f/0x190
[ 12.518366] ? switch_fpu_return+0x4e/0xd0
[ 12.518367] ? syscall_exit_to_user_mode+0x75/0x210
[ 12.518368] ? do_syscall_64+0x8f/0x190
[ 12.518369] ? do_syscall_64+0x8f/0x190
[ 12.518371] ? clear_bhb_loop+0x45/0xa0
[ 12.518372] ? clear_bhb_loop+0x45/0xa0
[ 12.518373] ? entry_SYSCALL_64_after_hwframe+0x76/0x7e
[ 12.518376] </TASK>
[ 12.518376] ---[ end trace 0000000000000000 ]---
[ 12.745821] iTCO_vendor_support: vendor-support=0
[ 12.817714] kauditd_printk_skb: 72 callbacks suppressed
[ 12.817716] audit: type=1130 audit(1726670782.676:52): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-catalog-update comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 12.843193] iTCO_wdt iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
[ 12.843303] iTCO_wdt iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 13.032033] iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 89.3.35.37
[ 13.225676] Bluetooth: hci0: Found device firmware: intel/ibt-19-0-4.sfi
[ 13.225688] Bluetooth: hci0: Boot Address: 0x24800
[ 13.225689] Bluetooth: hci0: Firmware Version: 132-3.24
[ 13.424646] snd_soc_avs 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040100
[ 13.424665] snd_soc_avs 0000:00:1f.3: Digital mics found on Skylake+ platform, using SOF driver
[ 13.793922] mousedev: PS/2 mouse device common for all mice
[ 14.087599] iwlwifi 0000:00:14.3: loaded firmware version 77.a20fb07d.0 QuZ-a0-hr-b0-77.ucode op_mode iwlmvm
[ 14.346135] r8152 2-1.1:1.0 enp0s13f0u1u1: renamed from eth0
[ 14.347803] intel_tcc_cooling: TCC Offset locked
[ 14.594484] pps_core: LinuxPPS API ver. 1 registered
[ 14.594486] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 14.596835] PTP clock support registered
[ 14.646745] nouveau 0000:01:00.0: bios: version 90.17.7e.00.19
[ 14.730888] mc: Linux media interface: v0.10
[ 14.880206] videodev: Linux video capture interface: v2.00
[ 14.920341] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX201 160MHz, REV=0x351
[ 14.920430] thermal thermal_zone18: failed to read out thermal zone (-61)
[ 15.044566] iwlwifi 0000:00:14.3: Detected RF HR B5, rfid=0x10a100
[ 15.112264] iwlwifi 0000:00:14.3: base HW address: bc:6e:e2:7b:b5:bf
[ 15.140440] Bluetooth: hci0: Waiting for firmware download to complete
[ 15.141187] Bluetooth: hci0: Firmware loaded in 1870613 usecs
[ 15.141220] Bluetooth: hci0: Waiting for device to boot
[ 15.156182] Bluetooth: hci0: Device booted in 14617 usecs
[ 15.156184] Bluetooth: hci0: Malformed MSFT vendor event: 0x02
[ 15.219573] usb 3-7: Found UVC 1.10 device HP HD Camera (0408:5441)
[ 15.221472] usb 3-7: Found UVC 1.50 device HP HD Camera (0408:5441)
[ 15.221937] usbcore: registered new interface driver uvcvideo
[ 15.280058] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-19-0-4.ddc
[ 15.282266] Bluetooth: hci0: Applying Intel DDC parameters completed
[ 15.283269] Bluetooth: hci0: Firmware revision 0.4 build 132 week 3 2024
[ 15.285293] Bluetooth: hci0: HCI LE Coded PHY feature bit is set, but its usage is not supported.
[ 15.323523] sof-audio-pci-intel-tgl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040100
[ 15.323551] sof-audio-pci-intel-tgl 0000:00:1f.3: Digital mics found on Skylake+ platform, using SOF driver
[ 15.323596] sof-audio-pci-intel-tgl 0000:00:1f.3: enabling device (0000 -> 0002)
[ 15.323865] sof-audio-pci-intel-tgl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if 0x040100
[ 15.323942] sof-audio-pci-intel-tgl 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 15.329408] audit: type=1130 audit(1726670785.186:53): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-resolved comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 15.330813] sof-audio-pci-intel-tgl 0000:00:1f.3: use msi interrupt mode
[ 15.391869] sof-audio-pci-intel-tgl 0000:00:1f.3: hda codecs found, mask 5
[ 15.391873] sof-audio-pci-intel-tgl 0000:00:1f.3: using HDA machine driver skl_hda_dsp_generic now
[ 15.391876] sof-audio-pci-intel-tgl 0000:00:1f.3: DMICs detected in NHLT tables: 4
[ 15.447204] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware paths/files for ipc type 0:
[ 15.447207] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware file: intel/sof/sof-tgl-h.ri
[ 15.447208] sof-audio-pci-intel-tgl 0000:00:1f.3: Topology file: intel/sof-tplg/sof-hda-generic-4ch.tplg
[ 15.447523] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware info: version 2:2:0-57864
[ 15.447524] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware: ABI 3:22:1 Kernel ABI 3:23:0
[ 15.447526] sof-audio-pci-intel-tgl 0000:00:1f.3: unknown sof_ext_man header type 3 size 0x30
[ 15.556508] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware info: version 2:2:0-57864
[ 15.556511] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware: ABI 3:22:1 Kernel ABI 3:23:0
[ 15.596272] audit: type=1130 audit(1726670785.453:54): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=modprobe@efi_pstore comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 15.596276] audit: type=1131 audit(1726670785.453:55): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=modprobe@efi_pstore comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 15.597821] audit: type=1130 audit(1726670785.456:56): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=modprobe@dm_mod comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 15.597824] audit: type=1131 audit(1726670785.456:57): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=modprobe@dm_mod comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 15.599365] audit: type=1130 audit(1726670785.456:58): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=modprobe@loop comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 15.599378] audit: type=1131 audit(1726670785.456:59): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=modprobe@loop comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 15.702024] sof-audio-pci-intel-tgl 0000:00:1f.3: Topology: ABI 3:22:1 Kernel ABI 3:23:0
[ 15.702144] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: Parent card not yet available, widget card binding deferred
[ 15.775572] audit: type=1130 audit(1726670785.633:60): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-vconsole-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 15.814659] snd_hda_codec_realtek ehdaudio0D0: autoconfig for ALC285: line_outs=1 (0x17/0x0/0x0/0x0/0x0) type:speaker
[ 15.814662] snd_hda_codec_realtek ehdaudio0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 15.814663] snd_hda_codec_realtek ehdaudio0D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 15.814664] snd_hda_codec_realtek ehdaudio0D0: mono: mono_out=0x0
[ 15.814664] snd_hda_codec_realtek ehdaudio0D0: inputs:
[ 15.814665] snd_hda_codec_realtek ehdaudio0D0: Mic=0x19
[ 16.416312] vga_switcheroo: enabled
[ 16.416430] nouveau 0000:01:00.0: DRM: VRAM: 4096 MiB
[ 16.416432] nouveau 0000:01:00.0: DRM: GART: 536870912 MiB
[ 16.480639] nouveau 0000:01:00.0: DRM: MM: using COPY for buffer copies
[ 16.526290] snd_hda_intel 0000:01:00.1: bound 0000:01:00.0 (ops nv50_audio_component_bind_ops [nouveau])
[ 16.530701] [drm] Initialized nouveau 1.4.0 20120801 for 0000:01:00.0 on minor 0
[ 16.534400] nouveau 0000:01:00.0: [drm] Cannot find any crtc or sizes
[ 16.545847] nouveau 0000:01:00.0: [drm] Cannot find any crtc or sizes
[ 16.546466] nouveau 0000:01:00.0: [drm] Cannot find any crtc or sizes
[ 16.547085] nouveau 0000:01:00.0: [drm] Cannot find any crtc or sizes
[ 16.547705] nouveau 0000:01:00.0: [drm] Cannot find any crtc or sizes
[ 16.584787] skl_hda_dsp_generic skl_hda_dsp_generic: hda_dsp_hdmi_build_controls: no PCM in topology for HDMI converter 3
[ 16.605270] input: sof-hda-dsp Mic as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card1/input28
[ 16.605296] input: sof-hda-dsp Headphone as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card1/input29
[ 16.605312] input: sof-hda-dsp HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card1/input30
[ 16.605328] input: sof-hda-dsp HDMI/DP,pcm=4 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card1/input31
[ 16.605344] input: sof-hda-dsp HDMI/DP,pcm=5 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card1/input32
[ 17.230358] audit: type=1130 audit(1726670787.086:61): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=modprobe@dm_mod comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 19.663248] Module nvidia is blacklisted
[ 20.110393] Module nvidia is blacklisted
[ 20.221166] kauditd_printk_skb: 5 callbacks suppressed
