i can’t install linux-Lts kernel with akm , how to fix this?
It needs your root password not your user password if they are different. You probably also want to install the headers as well. Fastest solution:
Open a terminal and copy paste this:
sudo pacman -S linux-lts linux-lts-headers
Update grub:
Reboot:
systemctl reboot
okay and i want install 2 kernel core/linux 5.15.11.arch2-1 and LTS can i do without any error?
Return inxi -Fxxxza --no-host
and copy paste the output.
after install LTS kernel then i need to type this? inxi -Fxxxza --no-host
No. I need that output first. Then we can proceed.
Kernel: 5.15.11-arch2-1 x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-linux
root=UUID=f6a8576a-f5f5-4f97-80c4-d9f09f712f5f rw quiet
resume=UUID=51d0d40f-9d8a-4cd0-b5b6-16ba5f2f5f5c loglevel=3 nowatchdog
nvme_load=YES
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Dell product: Inspiron 5575 v: 1.3.3
serial: <superuser required> Chassis: type: 10 v: 1.3.3
Mobo: Dell model: 0DRVH0 v: X01 serial: <superuser required> UEFI: Dell
v: 1.3.3 date: 10/31/2019
Battery:
ID-1: BAT1 charge: 1.1 Wh (100.0%) condition: 1.1/42.0 Wh (2.7%)
volts: 12.7 min: 11.4 model: SDI 0x4D,0x38,0x31,0x46,0x00,0x00,0x00E9
type: Li-ion serial: <filter> status: Full
Info: model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx bits: 64
type: MT MCP arch: Zen family: 0x17 (23) model-id: 0x11 (17) stepping: 0
microcode: 0x810100B
Topology: cpus: 1x cores: 4 tpc: 2 threads: 8 smt: enabled cache:
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1877 high: 3312 min/max: 1600/2000 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1354 2: 1353
3: 3288 4: 3312 5: 1466 6: 1531 7: 1369 8: 1350 bogomips: 31959
Vulnerabilities:
Type: spec_store_bypass
mitigation: Speculative Store Bypass disabled via prctl and seccomp
Type: spectre_v1
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
STIBP: disabled, RSB filling
Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
vendor: Dell driver: amdgpu v: kernel bus-ID: 03:00.0 chip-ID: 1002:15dd
class-ID: 0300
Device-2: Realtek Integrated Webcam type: USB driver: uvcvideo
bus-ID: 1-4:3 chip-ID: 0bda:568a class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.21.1.2 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2")
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.42.0
5.15.11-arch2-1 LLVM 13.0.0)
v: 4.6 Mesa 21.3.2 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 03:00.1 chip-ID: 1002:15de
class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.11-arch2-1 running: yes
Sound Server-2: JACK v: 1.9.19 running: no
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.42 running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel port: 2000 bus-ID: 01:00.0 chip-ID: 10ec:8136
class-ID: 0200
IF: enp1s0 state: down mac: <filter>
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Dell driver: ath10k_pci v: kernel bus-ID: 02:00.0
chip-ID: 168c:0042 class-ID: 0280
IF-ID-1: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
Bluetooth:
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 3-2.4:4
chip-ID: 0cf3:e009 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 0 state: down bt-service: disabled
Local Storage: total: 931.51 GiB used: 70.49 GiB (7.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: SDM3
scheme: GPT
ID-1: / raw-size: 922.42 GiB size: 906.86 GiB (98.31%)
used: 70.49 GiB (7.8%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 8.8 GiB used: 2.5 MiB (0.0%)
priority: -2 dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 74.0 C
Fan Speeds (RPM): cpu: 4900
Processes: 295 Uptime: 1h 6m wakeups: 1 Memory: 7.47 GiB
used: 6.16 GiB (82.4%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 Packages: 1102 pacman: 1097 lib: 303 flatpak: 5 Shell: Bash
v: 5.1.12 running-in: konsole inxi: 3.3.11
You already have the linux kernel installed.
Just do this to add the LTS kernel:
hit enter.
Update grub:
hit enter.
Reboot:
systemctl reboot
hit enter and select the lts kernel in grub when rebooting.
yes done thanks for commands
If you’re using akm, you just need to click on the ones you want and hit execute and everything will also be good to go. It’s a very basic program that essentially just runs those commands.
but i got error
You received an error because you entered the wrong password.
That was an authentication error. It was asking for your root password which was incorrect.
yes my old password working , but i want change root password
I have moved this to a new topic as you have many different questions it seems.
To change the root password:
sudo passwd root
