Endeavour reflector-simple won't update mirrors after fresh install
I got endeavour working on my laptop just fine, no issues, and moving to my computer, I repeated the exact same steps except with the Nvidia boot options instead. Brand new fresh install on a blank partition, and with all the default settings, I didn’t touch anything. Going onto the welcome page, I attempted to upgrade my mirrors for Arch and reflector-simple, and I got an error (Fetching information from https://www.archlinux.org failed!) I ran the reflector-simple command in the terminal and same thing. Also, opening firefox, I can access pretty much every website. I’ve tried both Ethernet and wifi connection, I use Google 1gb internet.
It looks like archlinux.org is down.
I can open the website fine on my phone, I dont know if there is a way to tell if the website is down though?
https://downforeveryoneorjustme.com/archlinux.org but I can access it on my phone as well!
Ah ok thank you, I probably should have remembered to check that, glad I’m not going crazy. Thanks for the help.
some issues with it for sure i see users complaining all over the place.
Error: error sending request for url (https://archlinux.org/mirrors/status/json/)
Yeah here we go again ehhh can’t thy just stop :person_facepalming:
