I have been using EndeavourOS for quite some time but for the past few days it has been freezing and the audio sounds crappy. I think this maybe caused by pipewire so i tried moving to pulseaudio but I cant firgure out how to do that
I hope someone here can help me because this has been my favourite distro so far
I have included the necessary logs here
(I apologise in advance if I messed up somewhere and included a bit too much info)
The system usually froze when I was using the browser for something and generally after I started playing some media like a video online or offline or playing music
sorry for being dumb but it doesn’t mention how to stop pulseaudio, I tried deleteing pulseaudio but it is required by a lot of other applications and same goes for pipewire
another problem that i am facing is significant input lag on both touchpad and keyboard, using Gnome on wayland in case you are wondering
Okay so I did a little digging and yea I believe the problem was pulseaudio and pipewire running side by side, I installed pipewire-pulse and it solved everything
