Emergency mode problem
Hello,
I have a problem whet booting into endeavour os, I tried to find a solution but cant find one that works for me yet.
(I’m quite unexperienced with linux in general.)
Here is the screen I get, and some of the things I tried
Hope someone can help me
run journalctl -xe to find out why your disk has a problem.
Did it, these are the two informations in red .
am I looking for something else?
Tanks for the support!
Please my computer is still fully stuck, can someone have a look?
Your root file system is damaged. Fsck cannot fix it. You can try to start a live system by usb boot, and run fsck manually. what kind of disk is that, ssd, harddisk ? If you get a live system running you might check smart data of the device, to see if it is a hardware failure. If that is the case fixing the file system by software is waste of time, you need to replace it.
Somehow it’s fixed. I used my live Usb and played around in the bios, and then I tried downloading a copy of my system onto the computer. That didn’t work, but then I could start the compurter again.
