Dropbox Installation
Yes but you can use just binaries instead where already compiled and for faster install.
i.e. notice how more votes and can choose brave-bin instead of brave below as example.
Brave Browser
Find the software you want and install using pacman command from Official Repo
If not there then yay command to install from Unofficial Arch User Repo . Look at votes, comments and package not out of date first.
But forum will always help best they can if create separate thread. Lots of reading from Arch wiki and Distrotube is great youtube channel for knowledge! :slight_smile:
Thanks for the reply.
As far as my humble understanding isn’t it better to compile (so that it compiles taking into consideration your own specific machine and software)?
Am I getting it right?
While that capability/possibility exists - it is NOT automatically given by choosing to compile. There are configuration(s) that can be set for that - but they don’t happen without you learning them and choosing them!
Most of the time, choosing a -bin version from the AUR is an advantage (especially time-wise) - after checking the PKGBUILD for content, and noticing the information provided with it in the AUR
(popularity counts, comments, etc).
ENjoy, either way…
Installing from AUR builds the packages yes, though be cautious of binaries in AUR
If you want you can always install the dropbox flatpak if you dont want to deal with AUR in this case.
Till now it is fine with me. I don’t care much if it takes some more time compiling if at the end I’ll get something like tailored for me.
I just do the yay command (as I find it anywhere), dont know even how to chose!
I am new to Arch in general, been on rpm and deb previously.
But Arch seems really interesting.
you can run
yay search terms
and it will give you a list. You can input the number of package you want to install.
Mmmm… I started in 2000 (SuSe and OpenSuse) till 2013, a few deb for a short while…
That time there was nothing (to my knowledge at least other than download and click/ double click the deb or rpm)
I see a lot has changed since 2013. I don’t even know what does flatpack mean. (Sorry, I’m a bit old, but always curious about learning new things)
All the info you need on flatpak :grinning_face_with_smiling_eyes:
https://www.flatpak.org/
https://wiki.archlinux.org/title/Flatpak
Thanks a lot Echoa
I’ll read as much as I can. And for sure I’ll be back again to ask lots of silly questions (away from Linux from like 8 years. A lot has changed I see)
only particularly silly question i could think of is
“Should I run sudo rm -rf / ?”
:upside_down_face:
the answer is no… lol
Why? I find it a convenient way to clean junk from my friends’ laptops.
:crazy_face:
OK! here is another silly question!
After the battle of installing dropbox several ways I have a few files in a folder /home/limo/Downloads/dropbox/
Can I simply delete this folder?
I suppose dropbox uses that folder to store your files.
Downloads folder isn’t touched while installing packages.
I dont use dropbox unfortunately so I cant say if thats safe or not :thinking:
As far as my “old brain” remember I believe it came from one of the links I tried above that included downloading and installing from the download (which didn’t happen), but prefer to hear from someone more experienced.
Don’t delete and check what is inside, if it is your documents that is in your Dropbox account then odd it decided to use that location to sync.
Ideally should be not be inside Downloads folder. Default it should /home/limo
See mine below. If dropbox decided to use Downloads. You can click “move” browse to /home/limo then dropbox folder moves there.
My data are already in /home/limo/Dropbox/
The folder in downloads have some files
/home/limo/Downloads/dropbox/src
/home/limo/Downloads/dropbox/dropbox.service
/home/limo/Downloads/dropbox/dropbox@.service
/home/limo/Downloads/dropbox/DropboxGlyph_Blue.svg
/home/limo/Downloads/dropbox/dropbox-lnx.x86_64-131.4.3968.tar.gz
/home/limo/Downloads/dropbox/dropbox-lnx.x86_64-131.4.3968.tar.gz.asc
/home/limo/Downloads/dropbox/PKGBUILD
/home/limo/Downloads/dropbox/terms.txt
/home/limo/Downloads/dropbox/update.sh
I believe they came from a previous installation attempt that didn’t work! I believe it can be deleted but I prefer to listen to someone more experienced.
What you think?
Yup can delete the dropbox folder within Downloads folder. They’re just source files.
Thanks QAP for your patience.
You know what, I’m glad the “old brain” of the “old me” is still functioning! :laughing: :laughing: :laughing: :+1:
