See the title, basically.
I saw a tip on (somewhere) the other day that the absolutely best way to avoid tearing in Linux if you run NVIDIA is to well… don’t. This hinges on not having a need for 3D rendering.
Thoughts on this? I don’t get tears in videos, but then I have set MPV to use hardware rendering. I DO get awful tearing when scrolling or moving windows around in all desktop environments except Gnome and Cinnamon (both using a different compositor than any other DE I have tried (Mutter / Muffin, closely related).
It may be hit-or-miss with nVidia, I don’t know. But Im running a GeForce GTX 770 2GB memory from eVga (nVidia GK104) with with nvidia 440.44-5 driver; no problems, no tearing. KDE/Plasma. This is an older card but runs just fine on the latest nvidia drivers.
I can run the Nvidia but i am using the dkms version. This card seems to work on the open source also. I’m not a gamer but i don’t notice any issues with it. First Nvidia card i have used. My new Ryzen i opted for the AMD RX590. Well see how that works out. I’m running Cinnamon right now on this Nvidia but i’m looking at KDE/Plasma on the new one. Still trying to figure out KDE and how it all works. How did you put the inxi summary on the page? Is it a link? How do you do that? I don’t know this platform on the forum well either.
Type some text. And then put the following in your edit screen.
<details>
<summary>
<i>Click for output</i>
</summary>
<p> Some descriptor or text.
Anything you put between <p> and </p> will be collapsed
</p>
</details>
Some more text if you want.
Note: if you use the three backtics trick to insert code in the collapsed portion a blank line before the first set of backtics is required.
