Hi, I’m new to these forums so I apologise if I’m breaking any rules. I’ve a fresh install of endeavouros, with nvidia drivers installed. I can get the game running on opengl but it runs quite slow. Vulkan won’t load past the initial icon screen. I’ve followed the archwiki page on how to get nvidia exclusively running. I’ve been trying for a few days now unsuccessfully to get it running. Any help would be deeply appreciated.
Please send output of
inxi -Faz
Thanks for the reply! Here’s the results
Kernel: 5.15.74-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-linux-lts
root=UUID=b6eb5a2b-ea94-486e-933c-0e23ab8960e2 rw loglevel=3 nowatchdog
nvme_load=YES nvidia-drm.modeset=1
Desktop: KDE Plasma v: 5.26.1 tk: Qt v: 5.15.6 wm: kwin_x11 vt: 1
dm: SDDM Distro: EndeavourOS base: Arch Linux
Type: Laptop System: HP product: OMEN by HP Laptop 15-dc0xxx v: N/A
serial: Chassis: type: 10 serial:
Mobo: HP model: 84DA v: 93.21 serial: UEFI: AMI
v: F.07 date: 10/30/2018
Battery:
ID-1: BAT0 charge: 37.1 Wh (100.0%) condition: 37.1/37.1 Wh (100.0%)
volts: 12.8 min: 11.6 model: HP Primary type: Li-ion serial: N/A
status: full
Info: model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF0
Topology: cpus: 1x cores: 6 tpc: 2 threads: 12 smt: enabled cache:
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 1128 high: 3421 min/max: 800/4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 3421 2: 1855 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 1071 12: 800
bogomips: 52799
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Vulnerabilities:
Type: itlb_multihit status: KVM: VMX unsupported
Type: l1tf mitigation: PTE Inversion
Type: mmio_stale_data mitigation: Clear CPU buffers; SMT vulnerable
Type: retbleed mitigation: IBRS
prctl and seccomp
sanitization
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20
ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Hewlett-Packard
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-10) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: lanes: 16 ports: active: none off: HDMI-A-2 empty: DP-2
bus-ID: 01:00.0 chip-ID: 10de:1c8d class-ID: 0300
Device-3: Lite-On HP Wide Vision HD Camera type: USB driver: uvcvideo
bus-ID: 1-6:8 chip-ID: 04ca:707f class-ID: 0e02 serial:
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia unloaded: intel alternate: fbdev,nouveau,nv,vesa
dri: iris gpu: i915,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 4480x1440 s-dpi: 110 s-size: 1036x333mm (40.79x13.11")
s-diag: 1088mm (42.84")
Monitor-1: HDMI-A-2 mapped: HDMI-0 note: disabled pos: primary,left
model: Gigabyte M27Q serial: built: 2021 res: 2560x1440 hz: 60
dpi: 109 gamma: 1.2 size: 596x335mm (23.46x13.19") diag: 684mm (26.9")
ratio: 16:9 modes: max: 2560x1440 min: 640x480
Monitor-2: eDP-1 mapped: eDP-1-1 pos: primary,right model: AU Optronics
0x23ed built: 2016 res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2
size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9
modes: 1920x1080
OpenGL: renderer: NVIDIA GeForce GTX 1050/PCIe/SSE2 v: 4.6.0 NVIDIA
520.56.06 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 1-1.3:9 chip-ID: 17cc:1830
alternate: snd_soc_skl,snd_sof_pci_intel_cnl class-ID: fe01
bus-ID: 00:1f.3 chip-ID: 8086:a348 serial: class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Device-3: Native Instruments Komplete Audio 1 type: USB
driver: snd-usb-audio
Sound API: ALSA v: k5.15.74-1-lts running: yes
Sound Server-2: PipeWire v: 0.3.59 running: yes
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
IF: wlan0 state: up mac:
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: eno1 state: down mac:
Bluetooth:
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:11 chip-ID: 8087:0aaa class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: up address: see --recommends
RAID:
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 5060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A
class-ID: 0104
Local Storage: total: 1.14 TiB used: 58.61 GiB (5.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung
model: MZVLB256HAHQ-000H1 size: 238.47 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial:
rev: EXD70H1Q temp: 41.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: rev: A3T0
scheme: GPT
ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%) used: 58.61 GiB
(25.1%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 312 KiB
(0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 57.0 C pch: 66.0 C mobo: N/A gpu: nvidia
temp: 52 C
Fan Speeds (RPM): N/A
Processes: 328 Uptime: 3m wakeups: 1 Memory: 15.44 GiB used: 2.51 GiB
(16.2%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1025 libs: 278 tools: yay
Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.22
