just a question if I understand the settings in Dolphin correctly:
I set Dolphin/Trash to clean up all files older than 7 days and set size limit to 1% (which is ~ 9 GB)
When I have a look at objects in trash I find files much older than 7 days (ref. to change date). How can this be. Do I need to do sth. else or will clean up happen only if I exceed th 1% limit additionally?
(I now set up “autotrash” to do what I supposed Dolphin should o…)
I don’t use the auto cleanup function, so this is just a guess, but - it’s only been 2 days since you activated the “Delete files older than 7 days” feature. I think you should wait until 7 days has passed before thinking it’s not working - the setting probably isn’t applied until 7 days after it has been first activated.
Try setting it to delete after 1 day, then wait 25 hours, and see if it deletes the files.
Short update: dolphin cleanup trash after x days definietly does NOTHING - at least here. Behaves like a dummy setting. If it was intended to work only in combination with the size limit then description and GUI is confusing.
I’ll open a bug report at least for clarification. Will return to autotrash now. Thanks for your input
