Hi, I’m on EndeavourOS and my Docker setup suddenly stopped being able to start any containers. My main goal is to get docker run --rm hello-world working again so I can safely back up and then migrate my containers to docker-compose.
Whenever I try to run a container, I get:
docker: Error response from daemon: failed to create task for container: failed to start shim: start failed: failed to create TTRPC connection: unsupported protocol:Yunix.
The same happens when I start containers via docker compose up -d.
What I’m running**:**
Distro: EndeavourOS (with CachyOS repos installed), fully updated via
sudo pacman -Syu -
Docker and containerd: installed from official repos (
pacman -S docker containerd) -
containerdbinaries:-
/usr/bin/containerd -
/usr/bin/containerd-shim-runc-v2 -
no
containerd-shimordocker-containerd-shimin/usr/local/bin
/etc/docker/daemon.jsondoes not exist
What I’ve already tried
- Restarted Docker multiple times:
sudo systemctl restart docker
Service is active, but any docker run fails with the error above.
- Fully updated and reinstalled docker + containerd:
sudo pacman -Syu docker containerd
sudo pacman -Rns docker containerd
sudo pacman -S docker containerd
Then:
sudo systemctl enable --now docker
Still get the same TTRPC / shim error.
- Confirmed there is no custom daemon config:
cat /etc/docker/daemon.json
# -> No such file or directory
- Checked for stray shims in
/usr/local/binand found none.
What I need help with:
- How to properly debug and fix this
failed to create TTRPC connection: unsupported protocol:Yunixerror on EndeavourOS. - What logs or configuration files I should share (e.g., full
journalctl -xeu docker.service) to pinpoint whether this is a containerd/runc mismatch, cgroups issue, or a known Arch/EndeavourOS bug.
I haven’t backed up most of the things in Docker and I’m relatively new to this. It was my fault just coming in blind installling docker containers without learning about them first.
I deeply appreciate any guidance. Thank you!
