I do not know where you are getting tracker and tracker-miners from. I can not find them in any repo and from what I understand they are old and obsolete. Therefore my system only has
In the Gnome Gitlab I did notice when then transitioned to tracker3, that not all programs were ready. So this is why they had the older one hanging around. But as@pebcak mentioned … looks like they fully transitioned over.
So the end solution is just to remove the packages as nothing needed them:
❯ sudo pacman -Rns tracker tracker-miners
[sudo] password for user:
checking dependencies...
Package (2) Old Version Net Change
tracker 1:2.3.6+r7+gb27396252-1 -4.36 MiB
tracker-miners 1:2.3.5+r3+gd9d61d87f-3 -2.36 MiB
Total Removed Size: 6.72 MiB
:: Do you want to remove these packages? [Y/n] y
:: Processing package changes...
(1/2) removing tracker-miners [------------------------------------] 100%
(2/2) removing tracker [------------------------------------] 100%
(1/2) Arming ConditionNeedsUpdate...
