Display issue when screen goes to sleep
Hello,
I am currently having some issue, hoping someone can help
New install
Wayland
GPU: RX 7900XTX
Screen 2x Samsung Odyssey G7 28"
When the screen go to sleep, and it gets woken up again the setting gets swapped between the monitors, one is horizontal the other is vertical so quite annoying to change back, with my head sideways and trying to control the mouse sideways.
One strange thing I also notice is that the “display configuration” menu only now has one visible screen on the “map” as seen from this screenshot: https://i.imgur.com/OKXwrq2.png
is there a way to lock this option? I have only been used to nvidia before, so not sure how to do it on AMD gpu
