Display issue: Display renders as 76:26
I am using an RTX 2060 graphics card if this helps.
The name says all the info I can really give. Yes, this is a desperate cry for help so that I can actually finally use EndeavourOS.
(SOLVED: I had to use the boot for newer Nvidia cards in the installer)
:crystal_ball:
Are you able to provide hardware information?
inxi -Fxxc0z | eos-sendlog
I was unable to even open the console. However, it was due to me using a newer Nvidia graphics card.
