Disk not mounting issue
so i tried mounting my disk (NTFS) using fstab but it doesnt work when my system boots up its unmounted always i tried running sudo mount -a my drive gets mounted but icons widgets on the system doesnt work started a browser and its starting brand new like it wasnt opened before which i did many times and after rteboot it got fixed but harddrive didnt automount
(i used defaults 0 0 )
wht could be the issue lying here
A little more detail will hopefully assist. Can you please share the output of:
$ lsblk -f
And:
$ cat /etc/fstab
okay
Your NTFS drive is trying to mount to the same mountpoint ( /home ) as one of your BTRFS sub-volumes.
You might try creating a new directory, perhaps within your home folder, and mounting it there instead.
Please post terminal output as text and not screenshots.
Copy the output, paste it into your reply, highlight it and press Ctrl-E to format.
Advantages: better readability, possibility to quote to comment on, searchable by the forum’s search function.
Thanks!
thnks a lot bro it worked :grin:
