Hi, I use the Xfce version. Is there a possibility to display the installed hard disks in the sidebar under Devices?
Greetings Scruggs
Greetings Scruggs
Do you mean that you would like to see your root partiton and then other partitions not inside of root as well as non system drives removable or otherwise on the left panel?
Don’t they show if you right click on “GERÄTE”?
No, never show, but the tip from @JR29 works perfekt. I have done this with nano. I love this OS!
