Detected unsafe path transition
I have a new installation of EOS. I’ve started seeing errors related to sssd that make no sense to be as I don’t even know what sssd is. below is a recent output from a “yay” command
( 1/11) Creating system user accounts...
( 2/11) Reloading system manager configuration...
( 3/11) Reloading user manager configuration...
( 4/11) Creating temporary files...
Detected unsafe path transition /etc/sssd (owned by sssd) → /etc/sssd/conf.d (owned by root) during canonicalization of etc/sssd/conf.d.
Detected unsafe path transition /etc/sssd (owned by sssd) → /etc/sssd/pki (owned by root) during canonicalization of etc/sssd/pki.
error: command failed to execute correctly
This is a EOS Plasma install with btrfs, grub-btrfs, snapper, snap-pac, and btrfs-assistant.
Jim A
It looks like this is due to permissions changing in the sssd package.
There is already discussion about it on this issue: https://gitlab.archlinux.org/archlinux/packaging/packages/sssd/-/issues/5
You can check and see what package on your system is requiring it with:
pactree -r sssd
pactree -r sssd
sssd
[jim@den-pc ~]$ sudo pactree -r sssd
[sudo] password for jim:
sssd
You can probably remove it if you don’t want it. It looks like nothing is depending on it.
Before I remove it, I’ll try the directory ownership fixes mentioned in the discussion you referenced.
I rechecked the link you referenced above and it’s now fixed. Plus I noticed the sssd package received an update.
