Dell XPS 13 (9350) Wireless Drivers
Your lspci -k does not show network. Where is it?
Your kernel might be tainted. Like mine: output of sudo dmesg before I remove broadcom-wl-dkms
Try this in terminal:
sudo pacman -R broadcom-wl-dkms
sudo rmmod wl
sudo modprobe brcmfmac
No need to reboot. If it works then you should be able to connect now.
brcm80211
The kernel contains two built-in open-source drivers: brcmfmac for native FullMAC and brcmsmac for mac80211-based SoftMAC. They should be automatically loaded when booting.
The Broadcom BCM4350 uses brcmfmac kernel module. Did you try uninstalling the broadcom packages.
Try as @boxer has posted above.
Nope, and nope. It seems that there’s a “signal” icon (or something) for Fn+PrtScr, but pressing it doesn’t seem to do anything.
Not sure about disabling bluetooth in BIOS, haven’t played around with it, I’ll try it later, but I updated BIOS from the Dell instructions about Linux (flash onto drive, F12 in BIOS, etc).
Nope, it used to have Windows but I’m pretty sure that it got erased.
Doesn’t seem to work, with sudo rmmode wl I get rmmod: ERROR: Module wl is not currently loaded.
Oh, update, I have no idea why but it suddenly decided to work after a reboot. Here’s what I did:
  1. Fn+PrtScr - This is apparently the newer shortcut for the hardware switch @anon11595408 was talking about. It didn’t give any indication that it did anything, but it might have.
  2. The following commands from @boxer:
sudo rmmod wl
It might have been because of the removal of the broadcom-wl-dkms package, or any of the other commands that I’m not sure about.
Thanks for all the help you guys gave, I appreciate it!
That is just to check that wl module is gone. The error you get is how it should be.
Glad it worked out :+1: :slightly_smiling_face:
Go to Dell website and download the pdf manual. In there it should clearly be stated what you somehow “reluctantly” found out. :laughing:
