My display goes dark after some period of inactivity. I don’t appreciate that and want to disable this “functionality.” It’s not related to power-profiles-daemon since I removed that, without relief. I find no obvious likely causes of this unwanted behavior when looking through running processes or installed software. Can someone please point me to what might be controlling this and how I can configure it?
you may want to check configs:
https://github.com/EndeavourOS-Community-Editions/openbox/blob/main/.config/openbox/autostart
and add something like this:
xset s 480 dpms 600 600 600
Modify DPMS and screensaver settings with a command
It is possible to turn off your monitor with the xset command which is provided by the xorg-xset package.
Examples:
| Command | Description |
xset s off |
Disable screen saver blanking |
xset s 3600 3600 |
Change blank time to 1 hour |
xset -dpms |
Turn off DPMS |
xset s off -dpms |
Disable DPMS and prevent screen from blanking |
xset dpms force off |
Turn off screen immediately |
xset dpms force standby |
Standby screen |
xset dpms force suspend |
Suspend screen |
Thank you! This was really useful information that helped me solve my issue and also learn something interesting (to me, anyway) about what’s going on inside my computer.
