For me the volume of EOS is too loud. My volume control works just fine but if I decrease it past 37% (in polybar) that may as well me 0%.
As a result that means everything can be on the too loud side.
Is there a way I can change the default settings so that polybar matches? Where are the default audio config files so I can change them manually? I’m using pipewire and not pulseaudio.
